Power-conserving WD AV-GP SATA hard drives take advantage of WD's GreenPower technology to meet the extreme requirements of demanding audio and video environments. With power reduction of up to 40%, they deliver cool and quiet operation and reliability perfect for audio video applications such as PVRs, DVRs, Set-Top Boxes (STBs) as well as surveillance video recording.
- WD AV-GP WD20EURX - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- IntelliSeek, Preemptive Wear Leveling (PWL), SilkStream, IntelliPower, NoTouch ramp load technology, Advanced Format technology
- 101.6 mm x 147 mm x 26.1 mm
- 640 g
- 3-year warranty
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 640 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 130 MBps
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Start / Stop Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 4.4 Watt (active) , 0.6 Watt (idle)
- RoHS
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Shock Tolerance
- 65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
- Sound Emission
- 23 dBA
