The My Passport portable drive is trusted to store the massive amounts of photos, videos and music you love. Available in an array of vibrant, fun colors, the sleek style fits comfortably in the palm of your hand, so you can easily take your treasured content everywhere you go.
Auto backup
Automatically back up photos, videos, music and documents from your system onto your My Passport drive with the included WD Backup software. Set it to your schedule. Just pick the time and frequency. -
Password protection
Built-in 256-bit AES Hardware Encryption with WD Security software helps keep your content private and safe. Easily add a "return-if-found" message as the password prompt in case your My Passport drive ever gets lost. Even great minds like yours can accidentally leave things behind. -
WD reliability
WD builds drives to demanding requirements for durability, shock tolerance and long-term reliability. -
Express yourself
The sleek, vibrant design of the My Passport drive comes in a wide range of bold, beautiful colors so you can pick the one that matches your own unique, personal style. -
Easy to use
Ready to use out of the box, you can start transferring files, saving memories and backing up right away. WD Backup and WD Security software is included to help protect your data.
- WD My Passport SSD WDBK3E2560PSL - SSD - 256 GB - USB 3.1 Gen 2
- Solid state drive - external (portable)
- Capacity
- 256 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.1 Gen 2 - USB-C
- Data Transfer Rate
- 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Shock resistant, password authentication, automatic backup
- Power Source
- USB bus
- Enclosure Colour
- Black top with gunmetal (medium metallic grey) bottom
- 45 mm x 90 mm x 10 mm
- Localisation
- Worldwide (excluding China)
- 3-year warranty
- Capacity
- 256 GB
- 256-bit AES
- Interface
- USB 3.1 Gen 2
- 45 mm
- 90 mm
- 10 mm
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 515 MB/s
Expansion & Connectivity
- 1 x USB 3.1 Gen 2 - 24 pin USB-C
- Power Source
- USB bus
- Software Included
- WD Security, WD Drive Utilities, WD Backup, WD Discovery
- OS Required
- Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS Sierra 10.12
- Cables Included
- 1 x USB-C cable , 1 x USB-C to USB-A adapter
- Directive 2002/95/EC
- Enclosure Colour
- Localisation
- Limited warranty - 3 years
- 5 °C
- 35 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 65 °C
