WD 256GB My Passport SSD USB 3.1 - Portable SSD
Quicklinx: F8FPWS00 Mfr#: WDBKVX2560PSL-WESN
Capacity: 256GB
Interface: USB 3.1 Gen 2
Type: External hard drive
17 in stock
£67.51 ex VAT
£81.01 inc VAT
The My Passport SSD is portable storage with blazing-fast transfers. Password protection with hardware encryption helps keep your content secure. Easy to use, the My Passport SSD is shock-resistant, compact storage in a cool, durable design.
  • Blazing-fast file transfers
    The My Passport SSD is the fastest My Passport drive to date with speeds up to 540 MB/s (using the USB Type-C port) to rapidly transfer data. Its speed also gives great performance to help run virtual machines on your computer.
  • Password protection with hardware encryption
    Store growing content on My Passport SSD to alleviate limited internal storage space. Set a password to help keep it protected with built-in 256-bit AES Hardware Encryption with WD Security software.
  • Trusted drive built with WD reliability
    Built to withstand a 6.5-foot (1.98 meters) drop test, My Passport SSD is engineered from the ground up by Western Digital to be a quality drive, inside and out, to deliver reliable performance.
  • Automatic backup
    Included WD Backup software makes it easy to automatically back up high-capacity files to your drive or Dropbox cloud service account. Just set it and forget it.
  • Easy to use
    My Passport SSD portable storage is ready to use out of the box. Whether backing up work docs or large media files, plug it in and start transferring right away.
WD My Passport SSD WDBKVX2560PSL - solid state drive - 256 GB - USB 3.1 Gen 2
Solid state drive - external (portable) - shock resistant, password authentication, automatic backup, Apple Time Machine compatible
256 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.1 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Shock resistant, password authentication, automatic backup, Apple Time Machine compatible
Power Source
USB bus
Enclosure Colour
Black top with gunmetal (medium metallic grey) bottom
45 mm x 90 mm x 10 mm
Worldwide (excluding China)
3-year warranty
256 GB
Hardware Encryption
256-bit AES
USB 3.1 Gen 2
45 mm
90 mm
10 mm
Performance
Interface Transfer Rate
Max Data Transfer Rate
540 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 2 - 24 pin USB-C
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD Backup, WD Discovery
Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS 10.12 Sierra
1 x USB-C cable , 1 x USB-C to USB-A adapter
Directive 2002/95/EC
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
Capacity: 256GB
Brand: WD
Price Range Ex VAT: 50 - 100
