WD 250GB Blue SATA-600 7200RPM 16MB 3.5"
Quicklinx: 78WTWS00 Mfr#: WD2500AAKX
WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. These drives are designed for use as primary drives in desktops PCs, external enclosures and for certain industrial applications.
  • The original
    WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives.
  • NoTouch ramp load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
  • WD quality
    Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs.
WD Blue WD2500AAKX - hard drive - 250 GB - SATA 6Gb/s
Hard drive - internal - Shock Guard, IntelliSeek, NoTouch ramp load technology
250 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
Shock Guard, IntelliSeek, NoTouch ramp load technology, S.M.A.R.T.
10.2 cm x 14.7 cm x 2.5 cm
450 g
250 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
16 MB
10.2 cm
14.7 cm
2.5 cm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
126 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^15
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
RoHS
60 °C
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 1ms (non-operating)
