With the performance boost from a WD Green SATA SSD, you can browse the web, play a game, or simply start your system in a flash. Lightweight and shock resistant, WD Green SSDs use no moving parts and help keep your data safe from loss in the case of accidental bumps and drops.
- WD Green PC SSD WDS240G1G0B - solid state drive - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Form Factor
- M.2 2280
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- DEVSLP SATA low power mode, S.M.A.R.T.
- 22 mm x 80 mm x 1.5 mm
- 6.51 g
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- M.2 2280
- Interface
- SATA 6Gb/s
- 22 mm
- 80 mm
- 1.5 mm
- 6.51 g
Performance
- SSD Endurance
- 80 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 465 MBps (write)
- 4KB Random Read
- 37000 IOPS
- 4KB Random Write
- 68000 IOPS
Reliability
- MTBF
- 1,750,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 50 mW (active) , 2000 mW (read) , 2500 mW (write) , 30 mW (sleep) , 3 mW (DevSleep)
- Software Included
- WD SSD Dashboard
- UL, TUV, VCCI, BSMI, FCC, KC
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Min Storage Temperature
- -55 °C
- Max Storage Temperature
- 85 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
- Vibration Tolerance (operating)
- 5 g @ 10-2000 Hz
- Vibration Tolerance (non-operating)
- 4.9 g @ 7-800 Hz
