With the performance boost from a WD Green SATA SSD, you can browse the web, play a game, or simply start your system in a flash. Lightweight and shock resistant, WD Green SSDs use no moving parts and help keep your data safe from loss in the case of accidental bumps and drops.
Improved performance for everyday computing
With the performance boost from a WD Green SATA SSD, you can browse the web, play a game, or simply start your system in a flash. -
Solid state reliability
Lightweight and shock resistant, WD Green SSDs use no moving parts and help keep your data safe from loss in the case of accidental bumps and drops. -
Less power, more play
WD Green SSDs are among the lowest power consuming drives in the industry. And with less power used, your laptop runs longer.
- WD Green PC SSD WDS240G1G0A - solid state drive - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- DEVSLP SATA low power mode, S.M.A.R.T.
- 69.85 mm x 100.5 mm x 7 mm
- 32 g
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
- 32 g
Performance
- SSD Endurance
- 80 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 465 MBps (write)
- 4KB Random Read
- 37000 IOPS
- 4KB Random Write
- 68000 IOPS
Reliability
- MTBF
- 1,750,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 50 mW (active) , 2000 mW (read) , 2500 mW (write) , 30 mW (sleep) , 3 mW (DevSleep)
- Software Included
- WD SSD Dashboard
- UL, TUV, VCCI, BSMI, FCC, KC
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Min Storage Temperature
- -55 °C
- Max Storage Temperature
- 85 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
- Vibration Tolerance (operating)
- 5 g @ 10-2000 Hz
- Vibration Tolerance (non-operating)
- 4.9 g @ 7-800 Hz
