WD 1TB Red SA500 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: FHNLWS00 Mfr#: WDS100T1R0A
Form Factor: 2.5
Capacity: 1TB, 1TB
Interface: Serial ATA-600
Type: Internal hard drive
17 In Stock
£68.33 ex VAT
£81.99 inc VAT
WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
  • Give it your tough workloads
    WD Red SSD's superior endurance can handle the heavy read and write loads demanded by NAS, giving you the reliability you need in a 24/7 environment.
  • Work more efficiently
    Purpose-built for NAS with proven Western Digital 3D NAND, the WD Red SSD delivers maximum SATA performance to boost your productivity and effectiveness at home or in the office.
  • Use it for your demanding applications
    The drive reduces latency and improves responsiveness for OLTP databases, multi-user environments, photo rendering, video editing, and more.
WD Red SA500 WDS100T1R0A - SSD - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
24x7 continuous operation, 3D NAND Technology
69.85 mm x 100.2 mm x 7 mm
37.4 g
5-year warranty
1 TB
2.5"
SATA 6Gb/s
69.85 mm
100.2 mm
7 mm
37.4 g
Performance
SSD Endurance
600 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 530 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
85000 IOPS
Reliability
MTBF
2,000,000 hours
24x7 Operation
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
60 mW (active) , 2550 mW (read) , 3750 Watt (write) , 56 mW (sleep) , 12 mW (DevSleep)
UL, TUV, VCCI, BSMI, FCC, KC, Morocco
Limited warranty - 5 years
70 °C
Min Storage Temperature
-55 °C
Max Storage Temperature
85 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (operating)
5 g @ 10-2000 Hz
Vibration Tolerance (non-operating)
4.9 g @ 7-800 Hz
Form Factor: 2.5
Capacity: 1TB
Capacity: 1TB
Brand: WD
