WD 1TB Purple 3.5" SATA 6Gb/s 5400RPM 64MB Surveillance Drive
Clearance!
Clearance
Limited Time Offer
Last Few Remaining
Quicklinx: CX86WS00 Mfr#: WD10PURZ
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 5400rpm
More than 50 in stock
£37.68 ex VAT
£45.21 inc VAT
WD Purple™ drives have been engineered specifically for surveillance, so they’re able to withstand the elevated heat fluctuations and equipment vibrations within a NVR environments. An average desktop drive is built to run for only short intervals, not the harsh 24/7 always-on environment of a high-definition surveillance system. A disruption to a drive could result in a failure that impacts multiple users, your security archive, or even the entire system. With WD Purple™, you get reliable, surveillance-class storage that’s tested for compatibility in a wide-range of security systems.
Industry-leading storage. Surveillance you can trust. WD is a worldwide leader in the hard drive industry. With WD Purple™ surveillance storage, you have a drive engineered for high temperature, always-on surveillance systems so you can rely on quality video playback when you need it most. Whether you’re protecting loved ones or monitoring your business, WD Purple™ offers performance you can trust.
Wide compatibility. Seamless integration. WD Purple™ hard drives are built with compatibility in mind, so you can quickly and seamlessly add capacity to your surveillance system. With a wide range of industry-leading enclosures and chipsets supported, you’re sure to find the DVR or NVR configuration that’s right for you.*
*Not sure what drive is best for your system? Use our compatibility tool to find the perfect storage for your DVR or NVR.
Expand your view to 64 Each WD Purple™ drive is optimized to support up to 64 cameras. With so many options, you have the flexibility to upgrade or expand your security system in the future.
  • Surveillance you can trust
    With WD Purple surveillance storage, you have a drive engineered for high temperature, always-on surveillance systems so you can rely on quality video playback when you need it most. Whether you're protecting loved ones or monitoring your business, WD Purple offers performance you can trust.
  • WD's exclusive AllFrame 4K technology
    All WD Purple drives are equipped with AllFrame 4K technology, which improves ATA streaming to help reduce frame loss, improve overall video playback, and increase the number of hard drive bays supported within a NVR. Futureproof your surveillance solution knowing that WD Purple is ready for ultra high definition cameras.
  • Enhanced workload rating
    With a high workload rating WD Purple is designed to handle the unique demands of modern video surveillance DVR and NVR systems.
  • Wide compatibility, seamless integration
    WD Purple hard drives are built with compatibility in mind, so you can quickly and seamlessly add capacity to your surveillance system. With a wide range of enclosures and chipsets supported, you're sure to find the DVR or NVR configuration that's right for you.
  • Less power, more efficient
    With exclusive IntelliSeek technology, WD Purple drives are able to calculate optimum seek speeds. This keeps power consumption low so ambient noise and vibrations are at a minimum.
WD Purple Surveillance Hard Drive WD10PURZ - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal - Time-Limited Error Recovery (TLER), Advanced Format technology, HelioSeal, surveillance system compatible, 24x7 availability, Write-Intensive Endurance, AllFrame 4K
1 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
101.6 mm x 147 mm x 26.1 mm
450 g
Worldwide
3-year warranty
1 TB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
110 MBps
Spindle Speed
5400 rpm
Reliability
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
3.3 Watt (read) , 3.3 Watt (write) , 2.9 Watt (idle) , 0.4 Watt (standby) , 0.4 Watt (sleep)
Directive 2002/95/EC
Worldwide
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
22 dBA
Form Factor: 3.5"
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: WD
Price Range Ex VAT: 0 - 50
