WD 1TB MyPassport Ultra 3.0 Portable Hard Drive - Wild Berry
Quicklinx: BD1HWS00 Mfr#: WDBGPU0010BBY-EESN
My Passport Ultra delivers USB 3.0 performance and high capacity in a sleek design. It features WD SmartWare Pro automatic backup software for back up to the drive itself or to your Dropbox account. Secure your files with password protection and hardware encryption.
  • Dependable
    Trust My Passport Ultra to help protect your precious memories and confidential files
  • Sleek design with high capacity
    With extreme capacities in the palm of your hand, My Passport Ultra is an ideal companion for your laptop or compatible tablets.
  • Ultra-fast transfer rates
    The power of USB 3.0 lets you access and save files in blazing-fast speed. Best of all, no separate power supply is needed.
  • You're in control
    Configure, manage and diagnose your drive with WD Drive Utilities. Run drive diagnostics, erase and format your drive, register your drive and more.
WD My Passport Ultra WDBGPU0010BBY - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, automatic backup, NTFS formatted, cloud backup
Power Source
USB bus
Enclosure Colour
Wild berry
81.57 mm x 110.07 mm x 15.84 mm
160 g
Middle East, Africa, Europe
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.0
81.57 mm
110.07 mm
15.84 mm
160 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities
Apple MacOS X, Microsoft Windows Vista / 7 / 8
1 x USB cable - external
RoHS
Enclosure Colour
Wild berry
Package Type
Retail
Limited warranty - 3 years
5 °C
35 °C
