WD 1TB My Passport SSD USB3.1 Portable SSD
Quicklinx: D1DBWS00 Mfr#: WDBK3E0010PSL-WESN
Select:
  • 1TB
The My Passport portable drive is trusted to store the massive amounts of photos, videos and music you love. Available in an array of vibrant, fun colors, the sleek style fits comfortably in the palm of your hand, so you can easily take your treasured content everywhere you go.
  • Auto backup
    Automatically back up photos, videos, music and documents from your system onto your My Passport drive with the included WD Backup software. Set it to your schedule. Just pick the time and frequency.
  • Password protection
    Built-in 256-bit AES Hardware Encryption with WD Security software helps keep your content private and safe. Easily add a "return-if-found" message as the password prompt in case your My Passport drive ever gets lost. Even great minds like yours can accidentally leave things behind.
  • WD reliability
    WD builds drives to demanding requirements for durability, shock tolerance and long-term reliability.
  • Express yourself
    The sleek, vibrant design of the My Passport drive comes in a wide range of bold, beautiful colors so you can pick the one that matches your own unique, personal style.
  • Easy to use
    Ready to use out of the box, you can start transferring files, saving memories and backing up right away. WD Backup and WD Security software is included to help protect your data.
WD My Passport SSD WDBK3E0010PSL - SSD - 1 TB - USB 3.1 Gen 2
Solid state drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.1 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Shock resistant, password authentication, automatic backup
Power Source
USB bus
Enclosure Colour
Black top with gunmetal (medium metallic grey) bottom
45 mm x 90 mm x 10 mm
Worldwide (excluding China)
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.1 Gen 2
45 mm
90 mm
10 mm
Performance
Interface Transfer Rate
Max Data Transfer Rate
515 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 2 - 24 pin USB-C
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD Backup, WD Discovery
Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS Sierra 10.12
1 x USB-C cable , 1 x USB-C to USB-A adapter
Directive 2002/95/EC
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
