WD 1TB My Passport for Mac Portable External Hard Drive - USB
Quicklinx: C0B0WS00 Mfr#: WDBJBS0010BSL-EESN
My Passport for Mac is secure and reliable. It safeguards your files with 256-bit AES hardware encryption and keeps your creative life safe with Apple Time Machine compatibility inside the precision design of a WD drive.
  • Compatible with Apple Time Machine
    Compatibility with Apple Time Machine makes it easy to regularly back up the files that define your creative life. Set up a backup schedule and rest assured that your files are protected.
  • Sleek design with high capacity
    With extreme capacities in the palm of your hand, My Passport for Mac is an ideal companion for your MacBook. Its stylish, compact design complements your on-the-go lifestyle.
  • Ultra-fast transfer rates
    The power of USB 3.0 lets you access and save files in blazing-fast speed. Best of all, because it's powered by the USB port, no separate power supply is needed.
  • You're in control
    Configure, manage and diagnose your drive with WD Drive Utilities. Run drive diagnostics, erase and format your drive, register your drive and more.
WD My Passport for Mac WDBJBS0010BSL - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, hardware encryption, Apple Time Machine compatible, HFS+ formatted
Power Source
USB bus
Enclosure Colour
Black/silver
110.07 mm x 81.57 mm x 15.84 mm
160 g
EMEA
Microsoft Certification
Compatible with Windows 7
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.0
110.07 mm
81.57 mm
15.84 mm
160 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities
1 x USB cable - external
Directive 2002/95/EC
Enclosure Colour
Black/silver
EMEA
Limited warranty - 3 years
5 °C
35 °C
