WD 1TB My Passport for Mac 2.5" USB 3.0 Portable Hard Drive
Quicklinx: CFGSWS00 Mfr#: WDBFKF0010BBK-WESN
Select:
  • 1TB
My Passport for Mac
My Passport for Mac is the sleek, portable hard drive designed for photographers, graphics professionals and road-warriors who want to take their digital life with them. It's compatible with Apple Time Machine and is an ideal companion for your MacBook or MacBook Air. Password protection and hardware encryption let you secure your files from unauthorized access.
Built for Mac, Time Machine-Ready
Ready to go with your Mac straight out of the box, the My Passport for Mac drive helps protect your files with Apple Time Machine backup software. And you can quickly drag and drop files to and from the drive with Finder.
Password Protection with Hardware Encryption
Built-in 256-bit AES hardware encryption with WD Security software helps keep your content private and safe. Add a 'return-if-found' message as the password prompt in case your My Passport for Mac drive ever gets lost.
Easy to Use
Ready to use out of the box with your Mac, you can start transferring files, saving memories and backing up. The My Passport for Mac drive works with Apple Time Machine, and included WD Security software helps protect your data.
Reimagined Design
Designed to complement your Mac, the rich, black shine and artful composition makes the My Passport for Mac drive fashionably fun.
Massive Capacity
With up to 4TB, you can take the massive amounts of photos, music and videos you love wherever you go, and have plenty of room for other important documents, too.
WD Quality Inside and Out
WD builds drives to demanding requirements for durability, shock tolerance and long-term reliability. And we stand behind the trusted My Passport for Mac drive with a 2-year limited warranty.
  • Sleek, compact design
    This compact enclosure offers plenty of storage making it the ideal companion for the graphic professional, student, or road warrior.
  • USB 2.0 interface
    Conveniently powered through the USB 2.0 interface, you can quickly connect to your MacBook or MacBook Air and access your files. There's no need to carry around a power adapter.
  • WD Security
    WD Security utility allows you to set password protection and hardware encryption for your drive to protect your files from unauthorized use or access.
  • WD Drive Utilities
    Register your drive, set drive timer, run diagnostics and more using the WD Drive Utilities.
  • Formatted for Mac
    HFS+ Journaled so it works right out of the box with your MacBook or MacBook Air. Can be reformatted for Windows.
  • Compatible with Apple Time Machine
    Back up your files with Apple Time Machine.
  • WD quality inside and out
    WD knows your data is important to you. So WD builds the drive inside to its demanding requirements for durability, shock tolerance, and long-term reliability. Then WD protects the drive with a durable enclosure designed for style and protection.
WD My Passport for Mac WDBFKF0010BBK - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, hardware encryption, Apple Time Machine compatible, HFS+ formatted
Power Source
USB bus
Enclosure Colour
110 mm x 81.5 mm x 16.3 mm
170 g
Worldwide (excluding China)
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.0
110 mm
81.5 mm
16.3 mm
170 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
Backup Software, WD Security, WD Drive Utilities
Microsoft Windows, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan
1 x USB 3.0 cable - external
Directive 2002/95/EC
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
