For use in laptops and desktop computers, WD Green SSDs offer high performance and reliability to boost your daily computing activities. With comprehensive WD F.l.T. Lab certification, and available in 2.5"/7mm cased form factor, WD Green solid state drives are compatible with most PCs.
Improved performance for everyday computing
Enhance your system with a WD Green solid state drive and help improve the performance of your laptop or desktop computer for your daily computing needs. SLC (single-level cell) caching technology helps boost write performance in a WD Green SSD to browse the web, play your favorite casual games, or simply start up your system in a flash. -
Solid state reliability
WD Green SSDs are built to be lightweight and shock-resistant to help protect against data loss if a drive is accidentally bumped or dropped. Combined with the comprehensive WD Functional Integrity Testing Lab (F.I.T. Lab) certification, every WD Green SSD is tested to ensure it meets the highest WD brand standards for digital storage. And with no moving parts in a WD Green SSD, you get reliable storage to withstand normal wear and tear for years to come.
- WD Green SSD WDS100T2G0A - SSD - 1 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1 TB
- NAND Flash Memory Type
- Single-level cell (SLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, S.M.A.R.T.
- 69.85 mm x 100.5 mm x 7 mm
- 32.7 g
- 3-year warranty
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.5 mm
- 7 mm
- 32.7 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 545 MBps
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 80 mW (active) , 2800 mW (read) , 2800 mW (write) , 30 mW (sleep) , 10 mW (DevSleep)
- Software Included
- WD SSD Dashboard
- UL, TUV, VCCI, BSMI, FCC, KC, NMB-3 Class B, CAN ICES-3 Class B
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Min Storage Temperature
- -55 °C
- Max Storage Temperature
- 85 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
- Vibration Tolerance (operating)
- 5 g @ 10-2000 Hz
- Vibration Tolerance (non-operating)
- 4.9 g @ 7-800 Hz
