Product
Brand
WD 1TB Elements USB 3.0 2.5" Portable Hard Drive
Quicklinx: 918MWS00 Mfr#: WDBUZG0010BBK-WESN
Form Factor: 2.5"
Capacity: 1TB
Interface: SuperSpeed USB
More than 50 in stock
£36.67 ex VAT
£44.00 inc VAT
Express delivery Delivered on Tuesday
WD Elements™ portable storage offers reliable, high-capacity storage to go, ultra-fast USB 3.0, universal connectivity, and massive capacity. Includes a free trial of WD SmartWare Pro backup software.
  • Maximum transfer rates: When connected to a USB 3.0 port, WD Elements delivers maximum performance for data transfers. Transfer a full-length HD movie in a fraction of the time it takes with USB 2.0.
  • USB 3.0 and USB 2.0 compatibility: Works seamlessly with the latest USB 3.0 devices and is backward compatible with USB 2.0 devices as well.
  • High capacity in a small enclosure: The small, lightweight design offers high-capacity storage, making WD Elements the ideal companion for value-conscious consumers who want to take their important files with them.
  • Free trial of WD SmartWare Pro backup software: WD Elements includes a free trial version of WD SmartWare Pro backup software. With it you can back up files to the local WD Elements drive or you can back up to the cloud using your Dropbox™ account.
  • Dropbox account required for cloud backup. Cloud services may be changed, terminated or interrupted at any time and may vary by country.
  • Improve PC performance: When your internal hard drive is almost full your PC slows down. Don't delete files. Free up space on your internal hard drive by transferring files to your WD Elements drive and get your PC moving again.
  • WD quality inside and out: We know your data is important to you. So we build the drive inside to our demanding requirements for durability, shock tolerance and long-term reliability. Then we protect the drive with a durable enclosure designed for style and protection.
  • Formatted for Windows®: Formatted NTFS and compatible with Windows 8, Windows 7, Windows Vista®, Windows XP. Can be reformatted for Mac®.
Ideal For
  • Adding extra storage for your videos, music, photos, and files.
  • Transferring data at maximum speed with USB 3.0
  • Backing up files using the free trial of WD SmartWare Pro backup software
  • Using with Windows® PCs
Kit Contents
  • Portable hard drive
  • USB 3.0 cable
  • Trial backup software launcher
  • Quick install guide
  • 2-year limited warranty - EMEA
WD Elements Portable WDBUZG0010BBK - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted, cloud backup
Power Source
USB bus
82 mm x 111 mm x 15 mm
134 g
Middle East, Africa, Europe
Microsoft Certification
Compatible with Windows 7
2 years warranty
1 TB
USB 3.0
82 mm
111 mm
15 mm
134 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD SmartWare Pro (30 days trial)
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable
Plug and Play, RoHS
5 °C
35 °C
Form Factor: 2.5"
Capacity: 1TB
Brand: WD
Price Range Ex VAT: 0 - 50
