WD 1TB Black 2.5" SATA 6Gb/s 7200RPM 32MB Cache Performance HDD
Maximum performance for power computing
Quicklinx: C1JFWS00 Mfr#: WD10JPLX
Form Factor: 2.5" x 1/8H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 7200rpm
£56.86 ex VAT
£68.23 inc VAT
Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
  • Great things come in small packages
    WD Black mobile hard drives are designed to enhance your PC experience, whether at home in your all-in-one desktop, or on-the-go in your trusty notebook. With plenty of storage running at high speed, you get a fast high-capacity mobile hard drive, offering the perfect storage solution for a digital artist, video editor, photographer, or gamer.
  • For creative professionals
    Give yourself the room to bring your enormous digital portfolio wherever you're at with WD Black mobile hard drives. With high-performance storage, WD Black mobile hard drives give you the power to create while on the go, so you can offload, edit, and shoot without fear of running out of space anytime soon.
  • For gamers
    WD Black mobile hard drives offer the perfect storage solution for your gaming rig. WD Black mobile hard drives are purpose-built to ensure they can handle the high-performance tasks you need.
WD Black Performance Hard Drive WD10JPLX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal - Advanced Format technology
1 TB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
32 MB
Spindle Speed
7200 rpm
69.85 mm x 100.2 mm x 9.5 mm
115 g
5-year warranty
1 TB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
32 MB
69.85 mm
100.2 mm
9.5 mm
115 g
Performance
Drive Transfer Rate
600 MBps (external)
Average Latency
3.5 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5" x 1/8H
Power Consumption
1.8 Watt (read) , 1.8 Watt (write) , 0.8 Watt (idle) , 0.2 Watt (standby) , 0.2 Watt (sleep)
RoHS, KCC, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years
60 °C
Shock Tolerance (operating)
400 g @ 2 ms
Shock Tolerance (non-operating)
1000 g @ 2 ms
Sound Emission
26 dBA
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: WD
Price Range Ex VAT: 50 - 100
