WD 1TB AV-GP SATA 6GB/s 3.5" 64MB Hard Drive
Quicklinx: 8BKQWS00 Mfr#: WD10EURX
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 5400rpm
£42.75 ex VAT
£51.30 inc VAT
Power-conserving WD AV-GP SATA hard drives take advantage of WD's GreenPower technology to meet the extreme requirements of demanding audio and video environments. With power reduction of up to 40%, they deliver cool and quiet operation and reliability perfect for audio video applications such as PVRs, DVRs, Set-Top Boxes (STBs) as well as surveillance video recording.
WD AV-GP WD10EURX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal - Native Command Queuing (NCQ), IntelliSeek, Preemptive Wear Leveling (PWL), SilkStream, IntelliPark, IntelliPower, GreenPower technology, Advanced Format technology
1 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
10.2 cm x 14.7 cm x 2.6 cm
0.6 kg
3-year warranty
1 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
10.2 cm
14.7 cm
2.6 cm
0.6 kg
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
110 MBps
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
RoHS
Limited warranty - 3 years
60 °C
Shock Tolerance
65 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: WD
Price Range Ex VAT: 0 - 50
