WD 1TB AV-GP SATA 3Gb/s 16MB 5400RPM 2.5" Hard Drive
The maximum energy-efficient cold storage HDD
Quicklinx: 8RH0WS00 Mfr#: WD10JUCT
Form Factor: 2.5" x 1/8H
Type: Hard drive
Interface Type: Serial ATA-300
Capacity: 1TB, 1TB
Spin Speed (rpm): 5400rpm
19 in stock
£59.96 ex VAT
£71.95 inc VAT
WD AV-25 2.5-inch SATA hard drives are specially engineered to offer cool quiet operation while providing maximum reliability in 24 x 7 always-on environments. With support for up to five simultaneous HD video streams, these drives are perfect for DVRs, digital video surveillance and other demanding multimedia applications.
  • 24 x 7 reliability
    These drives are designed to last in always-on streaming digital audio/video environments such as DVR/PVR, digital video surveillance and other demanding multimedia applications.
  • Advanced format technology
    Leading edge technology delivers improved video quality and AV performance through enhanced error correction capability.
  • SilkStream technology
    Optimized for smooth, continuous digital video playback of up to five simultaneous HD streams. SilkStream is compatible with the ATA streaming command set so AV customers can use standard streaming management and error recovery options.
  • Ultra-cool operation
    A cool drives is a more reliable drive. WD continues to develop new and innovative ways to keep drives cool while they are operating.
  • Quiet
    Noise levels have been minimized to less than one sone - virtually below the threshold of human hearing.
  • Low power consumption
    The drive draws less than 2 Watts while operating and a mere 4.75 Watts during spin up.
  • 1 million hours MTTF (MTBF)
    Best-in-class reliability for small-form factor AV storage.
  • Preemptive Wear Leveling (PWL)
    The drive arm frequently sweeps across the disk to reduce uneven wear on the drive surface common to audio video streaming applications.
WD AV-25 WD10JUCT - hard drive - 1 TB
Hard drive - internal - Preemptive Wear Leveling (PWL), SilkStream, Advanced Format technology
1 TB
2.5" x 1/8H
Data Transfer Rate
300 MBps
Buffer Size
16 MB
Spindle Speed
5400 rpm
70 mm x 100 mm x 9.5 mm
120 g
3-year warranty
1 TB
2.5" x 1/8H
Buffer Size
16 MB
70 mm
100 mm
9.5 mm
120 g
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
144 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
RoHS
Limited warranty - 3 years
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
8RH0 StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP In Stock £15.35
8RH0 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.39
8RH0 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.49
8RH0 StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £16.37
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: WD
Price Range Ex VAT: 50 - 100
