Transfer, save and protect your photos, videos, music and other massive files to free up valuable space on your computers. Featuring blazing-fast transfer speeds, hardware RAID and password protection, My Book Duo is the great storage solution offering the capacity and security you need.
Dual-drive performance with fast data transfers
Transfer a Full HD movie in seconds. Get the speed you need to transfer your entire media collection with ease. -
Massive capacity to hold all your large media files
My Book Duo is your storage vault. With great capacity, you can organize and save your entire photo, video and music collection, and other important documents in one safe place. -
Complete backup solutions to secure your data from loss
My Book Duo provides multiple backup possibilities to help protect your media collection and important files with local, cloud and system-level backup. -
Fast and reliable hardware encryption with password protection
My Book Duo provides password protection to ensure your entire media collection and important files are protected from unauthorized access. -
Expand capacity and organize your workspace
My Book Duo features two additional USB expansion ports allowing you to connect additional devices, such as another external drive to increase your storage, or simultaneously charge your smartphones, tablets or other USB devices. -
Easy to set up, easy to use
My Book Duo is pre-formatted NTFS and is ready to use right out of the box. -
User serviceable enclosure
Ready to upgrade your drives to expand storage capacity? With the simple push of a button, pop open the enclosure and insert new drives with ease. No tools required.
- WD My Book Duo WDBLWE0160JCH - hard drive array
- Hard drive array
- Total Array Capacity
- 16 TB
- Max Supported Capacity
- 16 TB
- Interface
- USB 3.0
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Localisation
- Middle East, Africa, Europe
- Built-in Devices
- USB 3.0 hub
- Storage Controller
- RAID RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 8 TB NTFS formatted
- OS Required
- Apple MacOS X, Microsoft Windows Vista / 7, Windows 10
- Power
- AC 120/230 V - 50/60 Hz
- 9.9 cm x 15.7 cm x 16.5 cm
- 2.81 kg
- 2-year warranty
- Hard drive array
- Localisation
Chassis
- Built-in Devices
- USB 3.0 hub
- 2
- Supported Devices / Modules Qty
- 2
Storage
- 16 TB
- 16 TB
- HDD Array External Interface
- USB 3.0
Storage Controller
- RAID
- Data Transfer Rate
- 290 MBps
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- Capacity
- 2 x 8 TB
- NTFS formatted
- Expansion Bays
- 2 (total) / 0 (free) x internal
- 2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B
- OS Required
- Hardware encryption, password security
- Cables Included
- 1 x USB 3.0 cable
- Software Included
- WD Security, WD Drive Utilities, WD SmartWare Pro
- AES-256
- Power Device
- External power adapter
- Voltage Required
- 9.9 cm
- 15.7 cm
- 16.5 cm
- 2.81 kg
- Limited warranty - 2 years
- 0 °C
- 35 °C
