Product
Brand
WD 16TB (2x8TB) My Book Duo USB3.0 RAID External Hard Drive
Quicklinx: C1SCWS00 Mfr#: WDBLWE0160JCH-EESN
Transfer, save and protect your photos, videos, music and other massive files to free up valuable space on your computers. Featuring blazing-fast transfer speeds, hardware RAID and password protection, My Book Duo is the great storage solution offering the capacity and security you need.
WD My Book Duo WDBLWE0160JCH - hard drive array
Hard drive array
Total Array Capacity
16 TB
Max Supported Capacity
16 TB
USB 3.0
2 (installed) / 2 (max)
Middle East, Africa, Europe
Built-in Devices
USB 3.0 hub
Storage Controller
RAID RAID 0, 1, JBOD
Hard Drive
2 x 8 TB NTFS formatted
Apple MacOS X, Microsoft Windows Vista / 7, Windows 10
AC 120/230 V - 50/60 Hz
9.9 cm x 15.7 cm x 16.5 cm
2.81 kg
2 years warranty
Hard drive array
Chassis
Built-in Devices
USB 3.0 hub
2
Supported Devices / Modules Qty
2
Storage
16 TB
16 TB
HDD Array External Interface
USB 3.0
Storage Controller
RAID
Data Transfer Rate
290 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
2 x 8 TB
NTFS formatted
Expansion Bays
2 (total) / 0 (free) x internal
2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B
Hardware encryption, password security
1 x USB 3.0 cable
Software Included
WD Security, WD Drive Utilities, WD SmartWare Pro
AES-256
External power adapter
9.9 cm
15.7 cm
16.5 cm
2.81 kg
35 °C
