WD 12TB Red Pro 3.5" SATA 6Gb/s 7200RPM 128MB NAS Hard Drive
Quicklinx: F8LJWS00 Mfr#: WD120EFAX
WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
  • Compatible
    Tested with a wide range of NAS systems for optimum performance and compatibility.
  • Reliable
    Designed to operate in the always-on environment of a NAS or RAID configuration.
  • High capacity
    The high capacity allows the flexibility to build the optimal NAS solution.
WD Red Plus WD120EFAX - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
5400 rpm
Native Command Queuing (NCQ), Advanced Format technology, NASware technology, 24x7 continuous operation, Error Recovery Control
3-year warranty
12 TB
3.5"
SATA 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5400 rpm
Reliability
24x7 Operation
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
RoHS 2011/65/EU
Limited warranty - 3 years
