Transfer, save and protect your photos, videos, music and other massive files to free up valuable space on your computers. Featuring blazing-fast transfer speeds, local, cloud and system-level backup options, hardware RAID and password protection, My Book Duo is the ultimate storage solution offering the capacity and security you need.
Dual-drive performance with up fast data transfers
Transfer a full HD movie in seconds. Get the speed you need to transfer your entire media collection with ease. -
Massive capacity to hold all your large media files
My Book Duo is your storage vault. With big capacity, you can organize and save your entire photo, video and music collection, and other important documents in one safe place. -
Complete backup solutions to secure your data from loss
My Book Duo provides multiple backup options to help protect your media collection and important files with local, cloud and system-level backup. -
Multiple data management options
Preconfigured in RAID 0 for maximum performance and capacity out-of-the-box or choose RAID 1 for ultimate data protection or JBOD to use the drives individually. True hardware RAID provides an independent CPU to manage RAID volumes and maximize bandwidth for reduced bottlenecks and improved data throughput. -
Fast and reliable hardware encryption with password protection
My Book Duo provides 256-bit AES hardware encryption; the most secure data encryption available. My Book Duo also provides password protection to ensure your entire media collection and important files are protected from unauthorized access. -
Expand capacity and organize your workspace with two high-speed USB 3.0 ports
My Book Duo features two additional USB expansion ports allowing you to connect additional devices, such as another external drive to increase your storage, or simultaneously charge your smartphones, tablets or other USB devices. -
Configure, manage and diagnose your drive with WD Drive Utilities
You're in complete control. With this software you can run drive diagnostics, manage RAID configurations, erase and format your drive, register your drive and more. -
Easy to set up, easy to use
My Book Duo is pre-formatted NTFS and is ready to use right out-of-the-box for Windows OS users. The drive can also be easily reformatted for Mac OS X. -
Ultra-reliable with WD Red NAS drives
My Book Duo ships with integrated WD Red NAS hard drives, designed and tested for reliability and optimal performance in small RAID environments. -
User serviceable enclosure
Ready to upgrade your drives to expand storage capacity? With the simple push of a button, pop open the enclosure and insert new drives with ease. No tools required.
- WD My Book Duo WDBLWE0120JCH - hard drive array
- Hard drive array
- Charcoal grey
- Total Array Capacity
- 12 TB
- Interface
- USB 3.0
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Localisation
- United Kingdom
- Storage Controller
- RAID RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 6 TB HDD
- OS Required
- Apple MacOS X, Microsoft Windows Vista / 7 / 8
- Power
- AC 120/230 V - 47/63 Hz
- 9.9 cm x 15.7 cm x 16.5 cm
- 2.31 kg
- 2-year warranty
- Hard drive array
- Enclosure Colour
- Charcoal grey
- Localisation
- United Kingdom
Chassis
- 2
- Supported Devices / Modules Qty
- 2
Storage
- 12 TB
- HDD Array External Interface
- USB 3.0
Storage Controller
- RAID
- Data Transfer Rate
- 290 MBps
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD
- Capacity
- 2 x 6 TB
- Expansion Bays
- 2 (total) / 0 (free) x internal
- 2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B
- OS Required
- Hardware encryption, password security
- Cables Included
- 1 x USB 3.0 cable
- Software Included
- WD Security, WD Drive Utilities, WD SmartWare Pro, Acronis True Image WD Edition
- RoHS, AES-256
- Power Device
- External power adapter
- Voltage Required
- 9.9 cm
- 15.7 cm
- 16.5 cm
- 2.31 kg
- Limited warranty - 2 years
- 0 °C
- 35 °C
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
