WD 10TB Red 3.5" SATA 6Gb/s 5400RPM 128MB NAS Hard Drive
Quicklinx: CX7MWS00 Mfr#: WD100EFAX
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 10TB
Spin Speed (rpm): 5400rpm
39 in stock
£256.86 ex VAT
£308.23 inc VAT
WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
  • Beyond desktop with NASware
    WD Red drives include WD's exclusive NASware technology that addresses many of the challenges a traditional desktop hard drive has in a NAS system. WD works directly with the partners to test compatibility and reduce thecustomer's guess work as to which drive is right for their NAS system. Designed to deliver a better customer experience in small NAS systems, this innovative firmware finely balances the most important attributes of performance, power, and reliability in multiple drive environments. The unique algorithms in NASware optimize power and performance without compromising on the attributes that NAS-system owner's value.
  • Important features for system integrators
    In addition to features that make WD Red drives perfect for populating or upgrading NAS systems, NASware brings features that system integrators need when building specialized NAS systems.
  • Save power and money
    NASware optimizes power use resulting in significant power savings and lower hard drive operating temperatures. This improves the overall reliability and performance of the drive and reduces the NAS cost of ownership.
  • Intelligent error recovery
    With built in intelligent error recovery controls, NASware also prevents hard drives from being dropped off the RAID due to extended error recovery. This provides more availability and less down time rebuilding the RAID.
  • Command completion
    To further improve reliability, NASware minimizes the data corruption or loss in the event of an unexpected power loss by completing the command in process before shutting down.
WD Red NAS Hard Drive WD100EFAX - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal - Native Command Queuing (NCQ), vibration dampening, Advanced Format technology, NASware technology, 24x7 continuous operation, Error Recovery Control
10 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
Native Command Queuing (NCQ), vibration dampening, Advanced Format technology, NASware technology, 24x7 continuous operation, Error Recovery Control, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
650 g
3-year warranty
10 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.6 mm
147 mm
26.1 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hour(s)
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
6.2 Watt (read) , 6.2 Watt (write) , 2.8 Watt (idle) , 0.5 Watt (sleep) , 0.5 Watt (standby)
TUV Nord, RoHS 2011/65/EU
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Form Factor: 3.5"
Type: Hard drive
Capacity: 10TB
Brand: WD
Price Range Ex VAT: 150 - 300
