WD Purple™ drives have been engineered specifically for surveillance, so they’re able to withstand the elevated heat fluctuations and equipment vibrations within a NVR environments. An average desktop drive is built to run for only short intervals, not the harsh 24/7 always-on environment of a high-definition surveillance system. A disruption to a drive could result in a failure that impacts multiple users, your security archive, or even the entire system. With WD Purple™, you get reliable, surveillance-class storage that’s tested for compatibility in a wide-range of security systems.
Industry-leading storage. Surveillance you can trust. WD is a worldwide leader in the hard drive industry. With WD Purple™ surveillance storage, you have a drive engineered for high temperature, always-on surveillance systems so you can rely on quality video playback when you need it most. Whether you’re protecting loved ones or monitoring your business, WD Purple™ offers performance you can trust.
Wide compatibility. Seamless integration. WD Purple™ hard drives are built with compatibility in mind, so you can quickly and seamlessly add capacity to your surveillance system. With a wide range of industry-leading enclosures and chipsets supported, you’re sure to find the DVR or NVR configuration that’s right for you.*
*Not sure what drive is best for your system? Use our compatibility tool to find the perfect storage for your DVR or NVR.
Expand your view to 64 Each WD Purple™ drive is optimized to support up to 64 cameras. With so many options, you have the flexibility to upgrade or expand your security system in the future.
With WD Purple surveillance storage, you have a drive engineered for high temperature, always-on surveillance systems so you can rely on quality video playback when you need it most. Whether you're protecting loved ones or monitoring your business, WD Purple offers performance you can trust. -
WD's exclusive AllFrame 4K technology
All WD Purple drives are equipped with AllFrame 4K technology, which improves ATA streaming to help reduce frame loss, improve overall video playback, and increase the number of hard drive bays supported within a NVR. Futureproof your surveillance solution knowing that WD Purple is ready for ultra high definition cameras. -
Enhanced workload rating
With a high workload rating WD Purple is designed to handle the unique demands of modern video surveillance DVR and NVR systems. -
Wide compatibility, seamless integration
WD Purple hard drives are built with compatibility in mind, so you can quickly and seamlessly add capacity to your surveillance system. With a wide range of enclosures and chipsets supported, you're sure to find the DVR or NVR configuration that's right for you. -
Less power, more efficient
With exclusive IntelliSeek technology, WD Purple drives are able to calculate optimum seek speeds. This keeps power consumption low so ambient noise and vibrations are at a minimum.
- WD Purple WD100PURZ - hard drive - 10 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 5400 rpm
- Time-Limited Error Recovery (TLER), Advanced Format technology, HelioSeal, surveillance system compatible, 24x7 availability, Write-Intensive Endurance, AllFrame 4K
- 101.6 mm x 147 mm x 26.1 mm
- 650 g
- Localisation
- Worldwide
- 3-year warranty
- Capacity
- 10 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.6 mm
- 147 mm
- 26.1 mm
- 650 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 210 MBps
- Spindle Speed
- 5400 rpm
Reliability
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 6.2 Watt (read) , 6.2 Watt (write) , 5 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
- Directive 2002/95/EC
- Localisation
- Worldwide
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 30 g @ 2 ms
- Shock Tolerance (non-operating)
- 250 g @ 2 ms
- Sound Emission
- 29 dBA
