WatchGuard Technologies XTM330 + 1 Year Live Security
Quicklinx: 8517WS00 Mfr#: WG330001
WatchGuard XTM 330 appliances deliver performance-driven network security for small businesses, with up to 1.4 Gbps firewall throughput, 240 Mbps VPN throughput, and seven 1-Gigabit Ethernet ports. Management tools include intuitive centralized console, command line interface and web UI. Real-time monitoring and rich reporting are included at no additional cost. Includes subscription to LiveSecurity Service for hardware warranty, technical support, and software updates.
WatchGuard XTM 330 - security appliance - with 1 year LiveSecurity Service
Security appliance
Bundled Services
External - 1U
Ports Qty
7
Performance
Firewall throughput: 1.4 Gbps , VPN throughput: 240 Mbps
Concurrent connections: 40000 , Branch office VPN tunnels: 50 , Mobile IPSec VPN tunnels: 5 , Mobile SSL VPN tunnels: 1 , Nodes (LAN IPs): unlimited
VoIP Protocols
H.323, SIP
43.2 cm x 28.6 cm x 4.5 cm
7.3 kg
Security appliance
Bundled Services
Height (Rack Units)
1U
Built-in Devices
Status LCD
43.2 cm
28.6 cm
4.5 cm
7.3 kg
External
Ports Qty
7
Wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPPoE, SMTP, FTP, DHCP, DNS, POP3
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS
Performance
Firewall protection, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, DiffServ support, Quality of Service (QoS), VPN failover, DHCP server, DHCP relay, DHCP client
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
VASCO token authentication, XAUTH (RADIUS, LDAP, Active Directory)
IP Telephony
VoIP Protocols
H.323, SIP
1 x management - RJ-45 , 2 x , 7 x 1000Base-T - RJ-45
Rack Mounting Kit
Included
CB, RoHS, WEEE, EAL 4+
Internal power supply
50 Watt
10 - 85% (non-condensing)
