Product
Brand
WatchGuard Technologies Firebox T70 with 1-yr Total Security Suite (WW)
Quicklinx: D31XWS00 Mfr#: WGT70641-WW
£1,754.04 ex VAT
£2,104.84 inc VAT
Many organizations today are dependent on fast, reliable and secure Internet connectivity, but are struggling to find network security solutions that can keep up with their ever growing needs. While many rack-mount solutions can keep up with today's fastest fiber-to-the-premises speeds, there are not currently any tabletop security appliances available that have this capability, especially when running with additional security services enabled. This makes it difficult for SMBs and distributed enterprises to harness these powerful Internet speeds with the complete UTM protection they require.
The WatchGuard Firebox T70 will make network slowdown concerns a thing of the past, with blazing-fast performance capable of delivering full UTM protection at over 1 Gigabit per second.
WatchGuard Firebox T70 - security appliance - with 1 year Total Security Suite
Security appliance
Bundled Services
External
Worldwide
Ports Qty
8
Performance
Firewall throughput: 4 Gbps , VPN throughput: 740 Mbps , Antivirus throughput: 1.2 Gbps , IPS throughput: 1.5 Gbps , Unified Threat Management (UTM) throughput: 1 Gbps , Connection rate: 27000 connections per second
Concurrent connections: 800000 , Virtual interfaces (VLANs): 75 , Authenticated users: 500 , Branch office VPN tunnels: 50 , Mobile IPSec VPN tunnels: 25 , Mobile SSL VPN tunnels: 60 , Mobile L2TP VPN tunnels: 60 , QoS hardware queues: 8
VoIP Protocols
H.323, SIP
Power Over Ethernet (PoE) Supported
PoE
AC 120/230 V
23.3 cm x 20.55 cm x 4.8 cm
Security appliance
Bundled Services
23.3 cm
20.55 cm
4.8 cm
Worldwide
External
Ports Qty
8
Wired
Network / Transport Protocol
TCP/IP, L2TP, IPSec, PPPoE, SMTP, FTP, DHCP, DNS, POP3, DDNS
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, CLI
Performance
NAT support, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, DiffServ support, IPv6 support, Intrusion Prevention System (IPS), deep inspection, anti-spam protection, Quality of Service (QoS), DHCP server, DHCP relay, DHCP client, Data Loss Prevention (DLP), proxy firewall, RapidDeploy, Reputation Enabled Defense, APT Blocker
Encryption Algorithm
DES, Triple DES, RSA, IKE, SSL, 128-bit AES, 192-bit AES, 256-bit AES, SHA-2
Authentication Method
SecurID, RADIUS, LDAP, Active Directory, VASCO token authentication
IEEE 802.3at
IP Telephony
VoIP Protocols
H.323, SIP
6 x 1000Base-T - RJ-45 , 1 x serial - RJ-45 , 2 x USB - Type A , 2 x 1000Base-T (PoE) - RJ-45
MTBF
65,000 hour(s)
CSA, UL, ICSA IPSec certified, ICSA Firewall certified, CB, RoHS, WEEE, REACH, Common Criteria EAL4+, IPv6 Ready
PoE
External power adapter
AC 120/230 V
5 - 90% (non-condensing)
Brand: WatchGuard Technologies
Price Range Ex VAT: 1500+
