WatchGuard Firebox T50, engineered for today's fast Internet connections, delivers enterprise-class protection from malware for small businesses and branch offices. Includes 7 GigE ports and 1 PoE (Power over Ethernet) port that can be used to power peripheral devices like wireless access points. Easy to deploy in remote locations. Provides excellent visibility into security events and network activity with real time visibility tools such as FireWatch and Traffic Monitor, all included at no additional cost.
- WatchGuard Firebox T50 - security appliance - with 1 year Total Security Suite
- Security appliance
- Bundled Services
- 1 year Total Security Suite
- Form Factor
- External
- Localisation
- Worldwide
- Ports Qty
- 7
- Data Link Protocol
- Performance
- Firewall throughput: 1.2 Gbps , VPN throughput: 270 Mbps , Antivirus throughput: 235 Mbps , IPS throughput: 410 Mbps , Unified Threat Management (UTM) throughput: 165 Mbps , Connection rate: 4600 connections per second
- Capacity
- Concurrent connections: 300000 , Virtual interfaces (VLANs): 75 , Authenticated users: 500 , Branch office VPN tunnels: 50 , Mobile IPSec VPN tunnels: 50 , Mobile SSL VPN tunnels: 50 , Mobile L2TP VPN tunnels: 50 , QoS hardware queues: 8
- VoIP Protocols
- H.323, SIP
- Power Over Ethernet (PoE) Supported
- PoE+
- Power
- AC 120/230 V
- 23.7 cm x 17.3 cm x 3.6 cm
- Bundled Services
- 23.7 cm
- 17.3 cm
- 3.6 cm
- Localisation
- Worldwide
- Form Factor
- External
- Ports Qty
- 7
- Connectivity Technology
- Wired
- PPPoE, DDNS
- Routing Protocol
- OSPF, BGP-4, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, CLI
- Performance
- Capacity
- NAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, DiffServ support, IPv6 support, Intrusion Prevention System (IPS), deep inspection, HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, TCP proxy, DHCP relay, DHCP client, Data Loss Prevention (DLP), proxy firewall, RapidDeploy, Reputation Enabled Defense, APT Blocker
- Encryption Algorithm
- DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, SHA-2
- Authentication Method
- SecurID, RADIUS, LDAP, Active Directory, VASCO token authentication
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3ad (LACP), IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
IP Telephony
- VoIP Protocols
- H.323, SIP
- 6 x 1000Base-T - RJ-45 , 1 x serial - RJ-45 , 2 x USB - Type A , 1 x 1000Base-T (PoE) - RJ-45
- MTBF
- 129,995 hour(s)
- ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, WEEE, REACH, IPv6 Ready
- PoE+
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 15 Watt
- Software Included
- WatchGuard Dimension
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
