Product
WatchGuard Technologies Firebox T50-W with 1-yr Total Security Suite (WW)
Quicklinx: D31WWS00 Mfr#: WGT51641-WW
  • IEEE 802.11n
WatchGuard Firebox T50-W, engineered for today's fast Internet connections, delivers enterprise-class protection from malware for small businesses and branch offices. Includes 7 GigE ports and 1 PoE (Power over Ethernet) port that can be used to power peripheral devices like wireless access points. Easy to deploy in remote locations. Provides excellent visibility into security events and network activity with real time visibility tools such as FireWatch and Traffic Monitor, all included at no additional cost.
WatchGuard Firebox T50-W - security appliance - with 1 year Total Security Suite
Security appliance
Bundled Services
External
Worldwide
Ports Qty
7
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall throughput: 1.2 Gbps , VPN throughput: 270 Mbps , Antivirus throughput: 235 Mbps , IPS throughput: 410 Mbps , Unified Threat Management (UTM) throughput: 165 Mbps , Connection rate: 4600 connections per second
Concurrent connections: 300000 , Virtual interfaces (VLANs): 75 , Authenticated users: 500 , Branch office VPN tunnels: 50 , Mobile IPSec VPN tunnels: 50 , Mobile SSL VPN tunnels: 50 , Mobile L2TP VPN tunnels: 50 , QoS hardware queues: 8
VoIP Protocols
H.323, SIP
Power Over Ethernet (PoE) Supported
PoE+
AC 120/230 V
23.7 cm x 17.3 cm x 3.6 cm
Security appliance
Bundled Services
23.7 cm
17.3 cm
3.6 cm
Worldwide
External
Ports Qty
7
Wireless, wired
Network / Transport Protocol
PPPoE, DDNS
Routing Protocol
OSPF, BGP-4, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
NAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, DiffServ support, IPv6 support, Intrusion Prevention System (IPS), deep inspection, HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, TCP proxy, DHCP relay, DHCP client, Data Loss Prevention (DLP), proxy firewall, RapidDeploy, Reputation Enabled Defense, APT Blocker
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, SHA-2
Authentication Method
SecurID, RADIUS, LDAP, Active Directory, VASCO token authentication
IEEE 802.11b, IEEE 802.11a, IEEE 802.3ad (LACP), IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
IP Telephony
VoIP Protocols
H.323, SIP
6 x 1000Base-T - RJ-45 , 1 x serial - RJ-45 , 2 x USB - Type A , 1 x 1000Base-T (PoE+) - RJ-45
MTBF
129,995 hour(s)
ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, WEEE, REACH, IPv6 Ready
PoE+
External power adapter
AC 120/230 V
15 Watt
Software Included
WatchGuard Dimension
10 - 85% (non-condensing)
