WatchGuard Technologies Firebox T10 with 1-yr Total Security Suite (UK)
Quicklinx: D31QWS00 Mfr#: WGT10641-UK
The WatchGuard Firebox T10 allows enterprise network security pros to build a new perimeter - one that matches the reality of today's distributed work style.
The Firebox T10 delivers complete enterprise-level network security. Ideal for small office/home office and small retail environments, it can be used as a stand-alone solution or centrally managed from corporate headquarters. Flexible management tools and WatchGuard's RapidDeploy technology enable administrators to quickly set up a T10 device at remote locations so businesses can ensure that they protect everywhere they connect. It sustains up to 200 Mbps firewall throughput and 55 Mbps UTM throughput, and includes three 1-Gigabit Ethernet ports. WatchGuard Dimension, which provides real-time visibility into network activity and security events, is included at no additional cost.
WatchGuard Firebox T10 - security appliance - with 1 year Total Security Suite
Security appliance
Bundled Services
19 cm
15.2 cm
3.2 cm
1.4 kg
United Kingdom
External
Ports Qty
3
Wired
Network / Transport Protocol
PPPoE, DDNS
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, CLI
Performance
Firewall throughput: 400 Mbps , VPN throughput: 100 Mbps , Antivirus throughput: 120 Mbps , IPS throughput: 160 Mbps , Unified Threat Management (UTM) throughput: 90 Mbps , Connection rate: 2300 connections per second
Concurrent connections: 50000 , Virtual interfaces (VLANs): 10 , Authenticated users: 200 , Branch office VPN tunnels: 5 , Mobile IPSec VPN tunnels: 5 , Mobile SSL VPN tunnels: 5 , Mobile L2TP VPN tunnels: 5 , QoS hardware queues: 8
NAT support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, DiffServ support, IPv6 support, Intrusion Prevention System (IPS), deep inspection, HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, TCP proxy, DHCP relay, DHCP client, Data Loss Prevention (DLP), proxy firewall, RapidDeploy, Reputation Enabled Defense, APT Blocker
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, SHA-2
Authentication Method
SecurID, RADIUS, LDAP, Active Directory, VASCO token authentication
IEEE 802.3ad (LACP)
IP Telephony
VoIP Protocols
H.323, SIP
3 x 1000Base-T - RJ-45 , 1 x serial - RJ-45 , 1 x USB - Type A
MTBF
129,995 hour(s)
ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, WEEE, REACH, IPv6 Ready
External power adapter
AC 120/230 V
15 Watt
Software Included
10 - 85% (non-condensing)
