WatchGuard Technologies Firebox T10-W with 1-yr Total Security Suite
Quicklinx: D31RWS00 Mfr#: WGT105641
  • IEEE 802.11n
The WatchGuard Firebox T10-W delivers enterprise-level security, making it ideal for small office/home office and retail environments. It can be used as a stand-alone security system or centrally managed from corporate headquarters. Flexible management tools and WatchGuard's RapidDeploy technology enable administrators to quickly setup the T10-W device at remote locations so businesses can ensure that they protect where they connect. With up to 200 Mbps firewall throughput, 55 Mbps UTM throughput, and three 1-Gigabit Ethernet ports. The Total Security Suite delivers security subscriptions to boost protection in critical attack areas, including Threat Detection and Response, APT Blocker, Data Loss Precention, Application Control, Intrusion Prevention Service, WebBlocker, Gateway AntiVirus, Reputation Enabled Defense, and spamBlocker, plus Gold level support. WatchGuard Dimension, for big-data style network visibility and Dimension Command - which enables management functionality - are also included.
WatchGuard Firebox T10-W - security appliance - Wi-Fi - with 1 year Total Security Suite
Security appliance
Bundled Services
External
Ports Qty
3
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall throughput: 400 Mbps , VPN throughput: 100 Mbps , Antivirus throughput: 120 Mbps , IPS throughput: 160 Mbps , Unified Threat Management (UTM) throughput: 90 Mbps , Connection rate: 2300 connections per second
Concurrent connections: 50000 , Virtual interfaces (VLANs): 10 , Authenticated users: 200 , Branch office VPN tunnels: 5 , Mobile IPSec VPN tunnels: 5 , Mobile SSL VPN tunnels: 5 , Mobile L2TP VPN tunnels: 5 , QoS hardware queues: 8
VoIP Protocols
H.323, SIP
AC 120/230 V
19 cm x 15.2 cm x 3.2 cm
1.4 kg
Security appliance
Bundled Services
19 cm
15.2 cm
3.2 cm
1.4 kg
External
Ports Qty
3
Wireless, wired
Network / Transport Protocol
TCP/IP, L2TP, PPPoE, SMTP, FTP, DHCP, DNS, POP3
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Performance
NAT support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, DiffServ support, IPv6 support, Intrusion Prevention System (IPS), deep inspection, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), DHCP server, DHCP relay, DHCP client, Data Loss Prevention (DLP), proxy firewall
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
SecurID, VASCO token authentication, XAUTH (RADIUS, LDAP, Active Directory)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3ad (LACP), IEEE 802.11g, IEEE 802.11n
IP Telephony
VoIP Protocols
H.323, SIP
3 x 1000Base-T - RJ-45 , 1 x serial - RJ-45 , 1 x USB - Type A
MTBF
129,995 hour(s)
ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, FIPS 140-2, WEEE, REACH, IPv6 Ready
External power adapter
AC 120/230 V
15 Watt
Software Included
10 - 85% (non-condensing)
