Firebox M400 firewall is specifically engineered for mid-sized and distributed enterprises that are struggling to effectively and affordably secure networks in the face of explosive growth in bandwidth rates, encrypted traffic, video use and connection speeds. The M400 can run all of their security scanning engines in parallel, ensuring network pros never have to compromise network security for performance. The Total Security Suite turns your Firebox M400 appliance into a comprehensive unified threat management solution. The suite includes powerful UTM security subscriptions that boost defenses in critical attack areas for maximum network protection. An exceptional value, each suite includes subscriptions to Threat Detection and Response, APT Blocker, Data Loss Prevention, Application Control, spamBlocker, Reputation Enabled Defense, WebBlocker, Gateway AntiVirus, and Intrusion Prevention Service, plus Gold level support, and Dimension Command.
Best-of-breed security
Application-layer content inspection recognizes & blocks threats that stateful packet firewalls cannot detect. Powerful subscription-based security services boost protection in critical attack areas for multiple layers of defense. By partnering with leading technology providers, WatchGuard is able to integrate best-of-breed security components into one platform for stronger security at big cost savings. -
Easy to manage
WatchGuard Dimension, a public and private cloud-ready visibility solution, instantly turns raw data into security intelligence. Interactive, real-time monitoring and reporting - at no additional charge - give an unprecedented view into network security activity so you can take immediate preventive or corrective actions. RapidDeploy enables quick, secure configuration at remote locations without technical staff. Intuitive management console centrally manages all security functions. WAN and VPN failover provide redundancy for increased reliability. Extend best-in-class UTM security to the WLAN by adding WatchGuard's Wireless Access Points. Drag-and-drop Branch Office VPN setup - three clicks and your remote office is connected.
- WatchGuard Firebox M400 - security appliance - with 1 year Total Security Suite
- Security appliance
- Bundled Services
- 1 year Total Security Suite
- Form Factor
- External - 1U
- Ports Qty
- 8
- Data Link Protocol
- Performance
- Firewall throughput: 8 Gbps , VPN throughput: 4.4 Gbps , Antivirus throughput: 2.5 Gbps , IPS throughput: 4 Gbps , Unified Threat Management (UTM) throughput: 1.4 Gbps , Connection rate: 84000 connections per second
- Capacity
- Concurrent connections: 3800000 , Virtual interfaces (VLANs): 300 , Authenticated users: unlimited , Branch office VPN tunnels: 100 , Mobile IPSec VPN tunnels: 150 , Mobile SSL VPN tunnels: 150 , Mobile L2TP VPN tunnels: 150 , QoS hardware queues: 8
- VoIP Protocols
- H.323, SIP
- Included Accessories
- Rack mount kit
- Power
- AC 120/230 V
- 43.1 cm x 30.5 cm x 4.4 cm
- Bundled Services
- Height (Rack Units)
- 1U
- 43.1 cm
- 30.5 cm
- 4.4 cm
- Form Factor
- External
- Ports Qty
- 8
- Connectivity Technology
- Wired
- TCP/IP, L2TP, PPPoE, SMTP, FTP, DHCP, DNS, POP3, DDNS
- Routing Protocol
- OSPF, BGP-4, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, CLI
- Performance
- Capacity
- NAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, DiffServ support, IPv6 support, High Availability, Intrusion Prevention System (IPS), deep inspection, HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), VPN failover, WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, TCP proxy, reset button, DHCP relay, on/off switches, DHCP client, Data Loss Prevention (DLP), proxy firewall, RapidDeploy, Reputation Enabled Defense, APT Blocker
- Encryption Algorithm
- DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, SHA-2
- Authentication Method
- SecurID, RADIUS, LDAP, Active Directory, VASCO token authentication
- IEEE 802.3ad (LACP)
IP Telephony
- VoIP Protocols
- H.323, SIP
- 6 x 1000Base-T - RJ-45 , 2 x 1000Base-X - SFP (mini-GBIC) , 1 x serial , 2 x USB
- Rack mount kit
- MTBF
- 51,644 hours
- ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, IPv6 Ready
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 75 Watt
- Software Included
- WatchGuard Dimension
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
