Get everything you need for unified threat management at a great price with the Firebox M200 with Security Suite. This bundle includes the WatchGuard M200 security appliance with 3.2 Gbps firewall throughput, 515 Mbps UTM throughput, and eight 1GgE ports. The Total Security Suite delivers powerful UTM security subscriptions to boost protection in critical attack areas, including Threat Detection and Response, APT Blocker, Data Loss Prevention, Application Control, Intrusion Prevention Service, WebBlocker, Gateway AntiVirus, spamBlocker, and Reputation Enabled Defense, along with Gold level support. WatchGuard Dimension, for big-data style network visibility and Dimension Command - which enables management functionality - are also included.
Comprehensive protection
Best-of-breed security services boost protection in critical attack areas, including gateway AV, URL and web content filtering, intrusion prevention, app control, and spam blocking. -
Real-time visibility
A suite of big-data style visibility and reporting tools are included with your Support contract. Use the Policy Map dashboard to quickly find active and misconfigured policies and drill down as needed. -
Outstanding performance
Up to 4 Gbps firewall throughput. Turn on optional security services and still see up to 800 Mbps throughput. -
3 ways to manage your appliance
You have the power to choose how you manage your WatchGuard appliance, including WatchGuard System Manager, the command line interface, and a web UI for access from anywhere, anytime. -
Maximum network uptime
High availability capabilities - active/active and active/passive - ensure your network is always up and running. -
VPN setup in seconds
Nothing could be easier than the drag-and-drop Branch Office VPN setup - three clicks and your remote office is connected. -
Block advanced persistent threats
Subscription-based APT Blocker takes over where AV protection leaves off, going after zero day threats for which there are no signatures. -
Data loss prevention
Prevent the loss of confidential data in motion with this subscription-based service. Includes built-in library of over 200 rules that allows IT to quickly create and update corporate DLP policies.
- WatchGuard Firebox M200 - security appliance - with 1 year Total Security Suite
- Security appliance
- Bundled Services
- 1 year Total Security Suite
- Form Factor
- Rack-mountable - 1U
- Ports Qty
- 8
- Data Link Protocol
- Performance
- Firewall throughput: 3.2 Gbps , VPN throughput: 1.2 Gbps , Antivirus throughput: 620 Mbps , IPS throughput: 1.4 Gbps , Unified Threat Management (UTM) throughput: 515 Mbps , Connection rate: 20000 connections per second
- Capacity
- Concurrent connections: 1700000 , Virtual interfaces (VLANs): 100 , Authenticated users: 500 , Branch office VPN tunnels: 50 , Mobile IPSec VPN tunnels: 75 , Mobile SSL VPN tunnels: 75 , Mobile L2TP VPN tunnels: 75 , QoS hardware queues: 8
- VoIP Protocols
- H.323, SIP
- Included Accessories
- Rack mount kit
- Power
- AC 120/230 V
- 43.1 cm x 30.7 cm x 4.4 cm
- Bundled Services
- Height (Rack Units)
- 1U
- 43.1 cm
- 30.7 cm
- 4.4 cm
- Form Factor
- Rack-mountable
- Ports Qty
- 8
- Connectivity Technology
- Wired
- TCP/IP, L2TP, IPSec, PPPoE, SMTP, FTP, DHCP, DNS, POP3, DDNS
- Routing Protocol
- OSPF, BGP-4, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, CLI
- Performance
- Capacity
- NAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, DiffServ support, IPv6 support, High Availability, Intrusion Prevention System (IPS), deep inspection, HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), VPN failover, WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, TCP proxy, reset button, DHCP relay, on/off switches, DHCP client, Data Loss Prevention (DLP), proxy firewall, RapidDeploy, APT Blocker
- Encryption Algorithm
- DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, SHA-2
- Authentication Method
- SecurID, RADIUS, LDAP, Active Directory, VASCO token authentication
- IEEE 802.3ad (LACP)
IP Telephony
- VoIP Protocols
- H.323, SIP
- 8 x 1000Base-T - RJ-45 , 1 x serial , 2 x USB
- Rack mount kit
- MTBF
- 51,644 hours
- ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, IPv6 Ready
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 75 Watt
- Software Included
- WatchGuard Dimension
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
