Product
Brand
WatchGuard Technologies Firebox M200 with 1-yr Total Security Suite
Quicklinx: D31YWS00 Mfr#: WGM20641
Type: Security appliance
Connectivity: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Compatibility: PC
£1,754.67 ex VAT
£2,105.60 inc VAT
Get everything you need for unified threat management at a great price with the Firebox M200 with Security Suite. This bundle includes the WatchGuard M200 security appliance with 3.2 Gbps firewall throughput, 515 Mbps UTM throughput, and eight 1GgE ports. The Total Security Suite delivers powerful UTM security subscriptions to boost protection in critical attack areas, including Threat Detection and Response, APT Blocker, Data Loss Prevention, Application Control, Intrusion Prevention Service, WebBlocker, Gateway AntiVirus, spamBlocker, and Reputation Enabled Defense, along with Gold level support. WatchGuard Dimension, for big-data style network visibility and Dimension Command - which enables management functionality - are also included.
WatchGuard Firebox M200 - security appliance - with 1 year Total Security Suite
Security appliance
Bundled Services
Rack-mountable - 1U
Ports Qty
8
Performance
Firewall throughput: 3.2 Gbps , VPN throughput: 1.2 Gbps , Antivirus throughput: 620 Mbps , IPS throughput: 1.4 Gbps , Unified Threat Management (UTM) throughput: 515 Mbps , Connection rate: 20000 connections per second
Concurrent connections: 1700000 , Virtual interfaces (VLANs): 100 , Authenticated users: 500 , Branch office VPN tunnels: 50 , Mobile IPSec VPN tunnels: 75 , Mobile SSL VPN tunnels: 75 , Mobile L2TP VPN tunnels: 75 , QoS hardware queues: 8
VoIP Protocols
H.323, SIP
Rack mount kit
AC 120/230 V
43.1 cm x 30.7 cm x 4.4 cm
Security appliance
Bundled Services
Height (Rack Units)
1U
43.1 cm
30.7 cm
4.4 cm
Rack-mountable
Ports Qty
8
Wired
Network / Transport Protocol
TCP/IP, L2TP, IPSec, PPPoE, SMTP, FTP, DHCP, DNS, POP3, DDNS
Routing Protocol
OSPF, BGP-4, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, CLI
Performance
NAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, DiffServ support, IPv6 support, High Availability, Intrusion Prevention System (IPS), deep inspection, HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), VPN failover, WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, TCP proxy, reset button, DHCP relay, on/off switches, DHCP client, Data Loss Prevention (DLP), proxy firewall, RapidDeploy, APT Blocker
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, SHA-2
Authentication Method
SecurID, RADIUS, LDAP, Active Directory, VASCO token authentication
IEEE 802.3ad (LACP)
IP Telephony
VoIP Protocols
H.323, SIP
8 x 1000Base-T - RJ-45 , 1 x serial , 2 x USB
Rack mount kit
MTBF
51,644 hours
ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, IPv6 Ready
Internal power supply
AC 120/230 V
75 Watt
Software Included
10 - 85% (non-condensing)
Connectivity: Wired
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: WatchGuard Technologies
Price Range Ex VAT: 1500+
