WASP WWS800 Bluetooth Wireless Scanner - No Base
Quicklinx: 9HJTWS00 Mfr#: 633808502317
Wasp Freedom Scanner gives you the wireless freedom to roam. With the Freedom, you can take your scanner to your inventory instead of your inventory to your scanner. The Wasp Freedom Scanner uses Bluetooth technology which allows you to scan bar codes and transmit the data upwards of 160 feet depending on the environment. Scan bar codes from 1 to 10 inches with aggressive CCD scan engine.
Wasp WWS800 Wireless Scanner - barcode scanner
Barcode scanner - handheld - Bluetooth - decoded
Scan Field Width
2.54 cm - 25.4 cm
Scan Element Type
CCD
Wireless
Wireless Connectivity
Bluetooth
Barcode
Interface Type
Bluetooth
Scan Field Width
2.54 cm - 25.4 cm
Scan Element Type
CCD
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, Telepen, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, French Pharmacode, Italy Pharmacode, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey, GS1 DataBar-14, Plessey
TTL Decoding
Decoded
Wireless
Bluetooth
