Product
WASP WWS450H 2D HLTHCRE SCNR
Quicklinx: 7YKDWS00 Mfr#: 633808524791
Type: Barcode scanner
Form Factor: Portable
Max Paper Size: [N/A]
Compatibility: PC
£443.29 ex VAT
£531.94 inc VAT
The Wasp WWS450H 2D barcode scanner is designed with healthcare environments in mind, allowing medical staff to treat patients efficiently and without errors. Built-in antimicrobial technology provides a level of protection against odor-and-stain causing bacteria.
Combined with versatility and efficiency, the WWS450H makes it easy to read 1D and 2D barcodes while staying connected wirelessly. Simply plug the USB adapter into a PC and the scanned barcode data is instantly and accurately transmitted back to your base from up to 160 feet away. Plus, the added buffer memory allows you to hold 256 scans, so you'll never need to worry about being out of range.
With an ergonomic form factor and antimicrobial protection, the WWS450H is comfortable to use for prolonged periods and will continue to fight bacteria for the lifetime of the scanner. The WWS450H offers a disinfectant-friendly housing to protect from alcohol cleaning, preventing discoloration, corrosions, and hardware malfunction.
Wasp WWS450H 2D Healthcare Barcode Scanner - barcode scanner
Barcode scanner - portable - decoded
United Kingdom
Minimum Bar Width
3 mil
Scan Field Width
2 cm - 56.9 cm
Scan Speed
100 scan / sec - 60 frames / sec
Wireless
Microsoft Windows Vista / XP / 7, Microsoft Windows 2003, Microsoft Windows Server 2008
9.3 cm x 6.1 cm x 15.3 cm
2 years warranty
United Kingdom
Barcode
Minimum Bar Width
3 mil
Scan Field Width
2 cm - 56.9 cm
Light Source Wave Length
625 nm
Scan Speed
100 scan / sec
Frame Rate
60 frames / sec
Max Working Distance
50.8 cm
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, TLC39, Australian Post, Japanese Post, Dutch Post, UK Post, EAN-3, Micro QR code, EAN-18
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
BSMI, FCC, RoHS, TELEC, KC
9.3 cm
6.1 cm
15.3 cm
50 °C
5 - 95%
Drop Specification
1.2 m to concrete
Compatibility: PC
Brand: WASP
Price Range Ex VAT: 300 - 500
