WASP WWS450 2D Barcode Scanner with USB Base
Quicklinx: 7YJZWS00 Mfr#: 633808524555
The Wasp WWS450 2D barcode scanner provides fast, efficient barcode scanning that your business depends on. The aggressive digital imager scan engine makes it ideal for scan-intensive applications.
Combined with versatility and efficiency, the WWS450 easily reads 1D and 2D barcodes while staying wirelessly connected. Simply plug the USB adapter into a PC and the scanned barcode data is instantly and accurately transmitted back to your base from up to 160 feet away. Plus, the added buffer memory allows you to hold 256 scans, so you'll never need to worry about being out of range.
Designed for durability and comfortable use, the WWS450 barcode scanner can withstand multiple 4-foot drops to concrete. The WWS450 base offers an adjustable desk or wall mountable feature.
Wasp WWS450 2D Barcode Scanner - barcode scanner
Barcode scanner - portable - decoded
United Kingdom
Minimum Bar Width
3 mil
Scan Field Width
2 cm - 56.9 cm
Scan Speed
100 scan / sec - 60 frames / sec
Wireless
Microsoft Windows Vista / XP / 7, Microsoft Windows 2003, Microsoft Windows Server 2008
9.3 cm x 6.1 cm x 15.3 cm
United Kingdom
Barcode
Minimum Bar Width
3 mil
Scan Field Width
2 cm - 56.9 cm
Light Source Wave Length
625 nm
Scan Speed
100 scan / sec
Frame Rate
60 frames / sec
Max Working Distance
50.8 cm
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, TLC39, Australian Post, Japanese Post, Dutch Post, UK Post, EAN-3, Micro QR code, EAN-18
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
1 x USB - Type A
Cradle
1 x USB cable - external
BSMI, FCC, RoHS, TELEC, KC
9.3 cm
6.1 cm
15.3 cm
50 °C
5 - 95%
Drop Specification
1.2 m to concrete
