WASP WWS-800 USB Scanner Kit
Quicklinx: 4CJCWS00 Mfr#: 633808500986
Type: Barcode scanner
Form Factor: Handheld
Max Paper Size: [N/A]
Compatibility: Mac, PC
£408.15 ex VAT
£489.78 inc VAT
Wasp Freedom Scanner Kit gives you the wireless freedom to roam. With the Freedom scanner, you can take your scanner to your inventory instead of your inventory to your scanner. The Wasp Freedom Scanner uses Bluetooth technology which allows you to scan bar codes and transmit the data upwards of 160 feet depending on the environment.
Wasp WWS800 Freedom Wireless Scanner Kit - USB - barcode scanner
Barcode scanner - handheld - Bluetooth
United Kingdom
Minimum Bar Width
5 mil
Scan Element Type
CCD
Scan Speed
100 scan / sec
Wireless
Wireless Connectivity
Bluetooth
Microsoft DOS, Apple MacOS, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows 95/98/ME/XP
7.3 cm x 15 cm x 9.1 cm
0.2 kg
United Kingdom
Barcode
Interface Type
Bluetooth
Minimum Bar Width
5 mil
Scan Element Type
CCD
Light Source Wave Length
650 nm
Scan Speed
100 scan / sec
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, Telepen, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, French Pharmacode, Italy Pharmacode, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey, GS1 DataBar-14
Wireless
Bluetooth
1 x USB
Cradle
1 x USB cable
FCC Class A certified, C-Tick
Battery charger
7.3 cm
15 cm
9.1 cm
0.2 kg
50 °C
0 - 95%
Compatibility: Mac
Compatibility: PC
Brand: WASP
Price Range Ex VAT: 300 - 500
