The WPL612 industrial barcode printer sets a standard for industrial barcode printing. It's the powerful barcode printer in the wasp line - delivering advanced print speeds, durable construction, and high-volume barcode printing in mission-critical applications. The WPL612 industrial barcode printer boasts all-metal construction for endurance and reliability in demanding environments.
Designed to offer seamless integration, the WPL612 includes an integrated LCD control panel for easy-set up and printer management. The WPL612 industrial barcode printer features a side-load media design, with a clear media viewing window to monitor ribbon and label usage.
- Wasp WPL612 - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 15 kg
- Max Media Size
- Roll (11.8 cm)
- Min Media Size (Custom)
- 25 mm
- Max Media Size (Custom)
- 118 mm
- Print Speed
- Up to 305 mm/sec
- Max Resolution (B&W)
- 203 dpi
- Interface
- Parallel, USB, LAN, serial
- RAM Installed (Max)
- 32 MB SDRAM
- Flash Memory Installed (Max)
- 8 MB
- Card Reader
- Language Simulation
- ZPL, EPL, WPL
- Barcodes
- Code 93, Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Code 128B, Code 128C, Code 128A
- Media Type
- Labels
- Networking
- Print server
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows 2000/XP/Vista/7/8
- 2-year warranty
- 27 cm x 50.5 cm x 30.8 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
Printer
- Print Speed
- Up to 305 mm/sec - 203 dpi
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 203 dpi
- ZPL, EPL, WPL
- Barcodes
RAM
- 32 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 8 MB
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Media Handling
- Media Type
- Labels
- Max Media Size
- Roll (11.8 cm)
- 25 mm
- 118 mm
- Media Sizes
- Roll (11.8 cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 4064 mm
- Roll Maximum Outer Diameter
- 208 mm
- Roll Core Diameter
- 76.2 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (11.8 cm)
- Networking
- Print server
- Connections
- 1 x serial , 1 x USB , 1 x LAN , 1 x parallel
- Included Accessories
- Rewind
- Cables Included
- 1 x USB cable
- FCC Class A certified, UL, TUV, cUL, CCC, C-Tick Class A
- OS Required
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 27 cm
- 50.5 cm
- 30.8 cm
- 15 kg
