WASP WPL612 Industrial Barcode Printer, 600 dpi
Quicklinx: BFB5WS00 Mfr#: 633808996277
The WPL612 industrial barcode printer sets a standard for industrial barcode printing. It's the powerful barcode printer in the wasp line - delivering advanced print speeds, durable construction, and high-volume barcode printing in mission-critical applications. The WPL612 industrial barcode printer boasts all-metal construction for endurance and reliability in demanding environments.
Designed to offer seamless integration, the WPL612 includes an integrated LCD control panel for easy-set up and printer management. The WPL612 industrial barcode printer features a side-load media design, with a clear media viewing window to monitor ribbon and label usage.
Wasp WPL612 - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
15 kg
Max Media Size
Roll (11.8 cm)
Min Media Size (Custom)
25 mm
Max Media Size (Custom)
118 mm
Max Resolution (B&W)
600 dpi
Parallel, USB, LAN, serial
RAM Installed (Max)
32 MB SDRAM
Flash Memory Installed (Max)
8 MB
Card Reader
Language Simulation
ZPL, EPL, WPL
Barcodes
Code 93, Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Code 128B, Code 128C, Code 128A
Media Type
Labels
Print server
Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows 2000/XP/Vista/7/8
27 cm x 50.5 cm x 30.8 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Built-in Devices
Status LCD
Wired
600 dpi
Language Simulation
ZPL, EPL, WPL
Barcodes
RAM
RAM Installed (Max)
32 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
8 MB
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Media Handling
Media Type
Labels
Max Media Size
Roll (11.8 cm)
25 mm
118 mm
Media Sizes
Roll (11.8 cm)
Max Printing Width
104 mm
Max Printing Length
4064 mm
Roll Maximum Outer Diameter
208 mm
Roll Core Diameter
76.2 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
Print server
1 x serial , 1 x USB , 1 x LAN , 1 x parallel
1 x USB cable
FCC Class A certified, UL, TUV, cUL, CCC, C-Tick Class A
5 °C
27 cm
50.5 cm
30.8 cm
15 kg
