WASP WPL305 Thermal Transfer Printer - Peeler Option
Quicklinx: 9HKFWS00 Mfr#: 633808500634
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Thermal transfer
£281.53 ex VAT
£337.83 inc VAT
The Wasp WPL305 is a compact, powerful desktop barcode printer designed to meet your light- to medium-duty barcode printing requirements. Its durable construction, speed, and dual printing technologies make the WPL305 a leader in its class.
The WPL305 offers both direct thermal and thermal transfer printing in one printer, reducing the need for investing in additional printers that only support one type of printing process. The Wasp WPL305 is a cost effective way to print labels of all types, including shipping labels, stock labels, asset tags, medical labels, and location labels.
The WPL305 prints at speeds up to 5 inches per second at 203 dpi print resolution. The WPL305 features 8 MB of operating DRAM, 2 MB of FLASH memory & Parallel, USB, RS232 connectivity. To ensure compatibility with your application, the WPL305 includes WPL, ZPL and EPL emulations.
The WPL305 is designed to be easy to install and use. Due to its reliability, it requires little maintenance. Optional upgrades such as peel & present, label cutter, additional memory cards, and Ethernet connectivity make the WPL305 one of the most versatile barcode printers of its kind. WPL305 thermal printers are CE, FCC, TUV, & UL certified and RoHS compliant.
Wasp WPL305 - label printer - monochrome - thermal transfer
Printer Type
Label printer - thermal transfer - monochrome
3 kg
Max Media Size
Roll (11.2 cm)
Max Media Size (Custom)
118 mm x 300 m
Print Speed
Up to 127 mm/sec
Max Resolution (B&W)
203 dpi
Parallel, USB, serial
RAM Installed (Max)
2 MB
Flash Memory Installed (Max)
1 MB (4 MB)
Barcodes
Code 93, Code 39, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix
Media Type
Labels
Total Media Capacity
1 roll
21.3 cm x 31.4 cm x 18.8 cm
Printer Type
Printer
Print Speed
Up to 127 mm/sec - 203 dpi
Wired
203 dpi
Barcodes
RAM
RAM Installed (Max)
2 MB
Flash Memory
Flash Memory
1 MB (installed) / 4 MB (max)
Media Handling
Media Type
Labels
Max Media Size
Roll (11.2 cm)
118 mm x 300 m
Media Sizes
Roll (11.2 cm), Roll (2 cm)
Max Printing Width
108 mm
Max Printing Length
990 mm
Media Weight
150 g/m²
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
1 x parallel , 1 x serial , 1 x USB
Cutter
UL, TUV, FCC
5 °C
25 - 85%
21.3 cm
31.4 cm
18.8 cm
3 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (11.2 cm)
Brand: WASP
Price Range Ex VAT: 150 - 300
