Product
WASP WPL25 Desktop Barcode Printer
Quicklinx: 9HKZWS00 Mfr#: 633808996253
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
£175.22 ex VAT
£210.26 inc VAT
The Wasp WPL25 direct thermal desktop printer creates 2-inch paper labels that are ideal for applications where small labels are necessary, including healthcare, retail, shipping, and office environments. Housed by a user-friendly, double-walled clamshell design, the WPL25 makes 5-inch outside diameter media changes quick and easy. Simply open the cover and drop your labels into the spring loaded media guide and begin printing at speeds up to 5 inches per second.
Supported by 8 MB SDRAM and 4 MB of Flash memory, the WPL25 enables you to maximize your workplace efficiency and productivity by using a 200 MHz, 32-bit RISC processor. With a MicroSD memory expansion slot, the WPL25 can easily store up to 4 GB of additional fonts or graphics. For space constrained environments, the WPL25 includes wall mountable holes on the bottom cover, providing you the option to have a wall mounted or desktop printer.
The WPL25 offers USB and RS232 serial connectivity allowing for easy integration into your existing environment. To ensure compatibility with your application, the WPL25 includes WPL, ZPL emulation, and EPL emulation and is FCC Class B, CE Class B, C-Tick Class B, UL, CUL, TUV/Safety, and CCC certified.
Wasp WPL25 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.8 kg
Max Media Size
Roll (6 cm)
Max Resolution (B&W)
203 dpi
USB, serial
200 MHz
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Card Reader
Language Simulation
ZPL, EPL, WPL
Barcodes
Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, China Post, Code 128B, Code 128C, Code 128A
Fonts
9 fonts
Styles & Effects
Rotated text
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
10.9 cm x 20.9 cm x 17.1 cm
Printer Type
Printer
Wired
USB, serial
203 dpi
Language Simulation
ZPL, EPL, WPL
Fonts
9 fonts
Styles & Effects
Rotated text
Fonts Included
8 x bitmapped , 1 x scalable
Barcodes
200 MHz
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Media Handling
Max Media Size
Roll (6 cm)
Max Printing Width
54 mm
Max Printing Length
2286 mm
Roll Maximum Outer Diameter
12.5 cm
Roll Core Diameter
25.4 mm, 38.1 mm
1 x USB 2.0 , 1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB cable
Wall mountable
FCC Class B certified, TUV, cUL, C-Tick Class B, CCC
Power supply - internal
5 °C
10.9 cm
20.9 cm
17.1 cm
1.8 kg
Type: Printer
Max Print Speed: [N/A]
Brand: WASP
Price Range Ex VAT: 150 - 300
