WASP WLS8600 Industrial Barcode Scanner w/ USB
Quicklinx: B4CPWS00 Mfr#: 633808929800
  • Windows 8 (32/64 bits)
The Wasp WLS8600 industrial barcode scanner features fuzzy logic technology for fast, accurate reading of damaged, dirty, and poorly printed one-dimensional (1D) barcodes typically found in industrial environments. In the yard, warehouse, distribution center, manufacturing plant or retail store, the WLS8600 industrial barcode scanner offers superior performance, reliability, and user-friendly ergonomics to improve productivity. Multiple on-board interfaces ensure flexible plug-and-play host connectivity.
  • Reads damaged 1D barcodes for maximum industrial productivity
  • Advanced data capture technology for tough environments
    As innovative as it is rugged, the WLS8600 delivers the ergonomic and operational features for scan-intensive industrial applications. The scanner operates in a wide range of temperatures and has a water and particulate sealing rating of IP65. The WLS8600 maintains its reliability even when subjected to repeated drops on concrete. For applications requiring quick access and convenient storage, the WLS8600 features a built-in metal hook for attachment. Two, large LED-enhancing windows and an extra loud beeper are strategically placed on the scanner to ensure the decode feedback is clearly visible and audible to users.
  • Capturing mission-critical information the smart way
    The standard WLS8600 was designed specifically for industrial applications. When you choose the WLS8600, you receive the added assurance of purchasing from Wasp.
Wasp WLS8600 Fuzzy Logic - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
3 mil
Scan Element Type
Visible laser diode
Scan Speed
35 scan / sec
Wired
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
6.9 cm x 11.4 cm x 20.7 cm
295 g
2 years warranty
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
630-680 nm
Scan Speed
35 scan / sec
Max Working Distance
97.8 cm
Print Contrast Signal (PCS)
15%
Decode Capability
Code 49, GS1 DataBar, Code 16K, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Stacked
TTL Decoding
Decoded
Wired
OK Notification
LED indicator
Reduced Space Symbology (RSS), waterproof, rugged
1 x USB - Type A
1 x USB cable - 1.83 m
RoHS, IP65
6.9 cm
11.4 cm
20.7 cm
295 g
Limited warranty - 2 years , Technical support - lifetime
-30 °C
50 °C
0 - 90% (non-condensing)
Drop Specification
2 m to concrete
