Product
WASP Wasp DT90 Mobile Computer Batch NO-WiFi/Bluetooth
Quicklinx: BZJ1WS00 Mfr#: 633808928612
  • Windows 8 (32/64 bits)
£924.79 ex VAT
£1,109.74 inc VAT
The DT90 features the best ergonomics on the market paired with the most comfortable and durable pistol grip handle in the industry. With its 38-key functional keypad, the DT90 is the premier solution for applications in retail, warehouse, and logistics environments. Whether in the stock room or the sales floor, the DT90 reduces operator fatigue without compromising efficiency or reliability.
The DT90's user interface comes equipped with at 3.2" high-visibility, color graphic display and an inclined scan engine so data on the screen can be viewed simultaneously while scanning barcodes. Offered with Microsoft Windows CE 6.0, the DT90 is powered by a 624 MHz microprocessor with 32-bit coprocessor. Its internal components are protected by a ruggedized housing that is sealed against moisture and dust and is capable of resisting multiple 5 foot drops to concrete. The DT90's integrated laser scanner can read all standard one-dimensional (1D) barcodes including GS1 Databar linear barcodes.
Wasp DT90 - data collection terminal - Win CE 6.0 Pro - 512 MB - 3.2"
Data collection terminal - rugged
Operating System
Microsoft Windows CE 6.0 Professional
Display
3.2" colour TFT - LED backlight - 240 x 320
Intel XScale PXA310
Processor Clock Speed
624 MHz
Storage
512 MB
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Barcode Reader
Yes (laser)
Barcodes
GS1 DataBar
Battery Run Time
Up to 11.1 hours
7.6 cm x 4.2 cm x 19.3 cm
392 g
1 year warranty
Operating System
Display
3.2" colour TFT (transflective) - LED backlight
Resolution
240 x 320
Intel XScale PXA310
624 MHz
Storage
512 MB
RAM
256 MB
microSD, microSDHC
Max Supported Capacity
32 GB
Input Device
Touch-screen, keypad
Keys Qty
38
Barcodes
Barcode Reader
Scan Element Type
Laser
Barcodes
GS1 DataBar
System Requirements for PC Connection
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
Expansion and Connectivity
Expansion Slots
1 x microSDHC
Lithium Ion
3000 mAh
Run Time
Up to 11.1 hours
Touch screen interface, Green Spot technology, drop-resistant
Power adapter, stylus, hand strap
USB cable
IEC 60529 IP64
7.6 cm
4.2 cm
19.3 cm
392 g
Limited warranty - 1 year , Technical support - lifetime
-10 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Brand: WASP
Price Range Ex VAT: 750 - 1000
