The DT90 features the best ergonomics on the market paired with the most comfortable and durable pistol grip handle in the industry. With its 38-key functional keypad, the DT90 is the premier solution for applications in retail, warehouse, and logistics environments. Whether in the stock room or the sales floor, the DT90 reduces operator fatigue without compromising efficiency or reliability.
The DT90's user interface comes equipped with at 3.2" high-visibility, color graphic display and an inclined scan engine so data on the screen can be viewed simultaneously while scanning barcodes. Offered with Microsoft Windows CE 6.0, the DT90 is powered by a 624 MHz microprocessor with 32-bit coprocessor. Its internal components are protected by a ruggedized housing that is sealed against moisture and dust and is capable of resisting multiple 5 foot drops to concrete. The DT90's integrated laser scanner can read all standard one-dimensional (1D) barcodes including GS1 Databar linear barcodes.
- Wasp DT90 - data collection terminal - Win Embedded Handheld 6.5 - 512 MB - 3.8" - with Additional Mobile Device License IC
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows Embedded Handheld 6.5
- Display
- 3.8" colour TFT - 800 x 480
- Processor
- Marvell PXA320 PXA320
- Processor Clock Speed
- 806 MHz
- Storage
- 512 MB
- RAM
- 256 MB
- Supported Flash Memory Cards
- microSD, microSDHC
- Wireless Connectivity
- 802.11a/b/g/n
- Rear Camera
- 5 Megapixel
- Barcode Reader
- Yes (laser)
- Barcodes
- Code 93, Matrix 2 of 5, Code 39, ISBT 128, GS1 DataBar, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, ITF, TLC39, Australian Post, British Post, Canadian Post, IATA 2 of 5, UPC-E1, EAN-UCC Composite, ITF-14
- Battery Run Time
- Up to 8.14 hours
- 4 cm x 17.7 cm x 7.4 cm
- 390 g
- 1-year warranty
- Bundled with
- Additional Mobile Device License IC
- Product Type
- Operating System
- Bundled with
Display
- 3.8" colour TFT
- Resolution
- 800 x 480
- Processor
- 806 MHz
- Storage
- 512 MB
- RAM
- 256 MB
- Max Supported Capacity
- 32 GB
Communications
- 802.11a/b/g/n
Rear Camera
- Sensor Resolution
- 5 Megapixel
Input Device
- Touch-screen, 26 keys numeric keyboard
Barcodes
- Barcode Reader
- Scan Element Type
- Laser
- Barcodes
System Requirements for PC Connection
- OS Required
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
Expansion and Connectivity
- Expansion Slots
- 1 x microSDHC
- Technology
- Lithium Ion
- Capacity
- 2200 mAh
- Run Time
- Up to 8.14 hours
- Included Accessories
- Power adapter, stylus
- Cables Included
- USB cable
- VCCI, BSMI, CCC, FCC, RoHS, IP65
- 4 cm
- 17.7 cm
- 7.4 cm
- 390 g
- Limited warranty - 1 year , Technical support - lifetime
- -10 °C
- 50 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
