Product
WASP Inventory Control RF Enterprise - (v. 6) - Product Upgrade Package
Quicklinx: 80MGWS00 Mfr#: 633808524357
Get in control of your stock with Wasp Inventory Control - the complete stock management solution for small business. Increase the value of your business, satisfy your customers and create more freedom in your life with Inventory Control.
Engineered to improve efficiency and profitability, Wasp Inventory Control provides the capabilities you need to accurately track stock, without the complexity or expense of an enterprise solution. Easy, efficient, affordable!
Inventory Control allows you to define multiple sites (a warehouse, truck fleet, stock room, or even an installation truck such as a TV or satellite installer) with multiple locations (a bin, shelf, or even a pallet within the location). It's simple to track your stock by location, serial number, lot or any combination of the numerous 'track bys'.
Easily create barcode labels with Wasp Inventory Control. Print barcode labels or stock tags using data from the Inventory Control database. Attach barcoded labels to stock items, physical locations or pallets to quickly improve efficiency.
Inventory Control RF Enterprise (v. 6) - box pack (upgrade) - 5 mobile devices, unlimited PCs
Box pack (upgrade)
Category
Business applications - inventory systems
Version
6
Licence Qty
Upgrade from
Wasp MobileInventory Network Edition v. 3 , Inventory Control Professional v. 4 , Inventory Control Professional v. 5 , Inventory Control RF Professional v. 6
Platform
Windows, Pocket PC
Distribution Media
DVD-ROM
Technical support
Category
Box pack (upgrade)
Version
6
Platform
Windows, Pocket PC
Upgrade from
Distribution Media
DVD-ROM
Min Supported Colour Depth
8-bit (256 colours)
Licencing
Licence Type
Supported OS
Microsoft Windows XP Professional x64 Edition SP3, Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows XP Professional SP3, Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows CE 4.2 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Mobile 5.0 or later
Hardware Requirements
Microsoft Windows Server - 750 MHz - RAM 1 GB - HD 10 GB , Microsoft Windows Mobile 5.0 or later - RAM 64 MB , Microsoft Windows CE 4.2 or later - RAM 64 MB , Microsoft Windows Vista / XP / 7 - 750 MHz - RAM 1 GB - HD 10 GB
Additional Requirements
DVD-ROM, network adapter, XGA monitor
Technical support - unlimited
