Product
WASP CountIt
WASP CountIt
Quicklinx: BF7QWS00 Mfr#: 633808341237
Type: Business - inventory systems
Compatibility: PC
License: Box pack
£142.86 ex VAT
£171.43 inc VAT
Wasp CountIt is an affordable, QuickBooks compatible software program designed for counting inventory. CountIt allows you to quickly download existing inventory information from QuickBooks directly to a mobile computer, take inventory, and then send the updated counts back to QuickBooks. Faster and easier inventory counts means spending less time counting inventory and more time controlling it.
Programs such as QuickBooks don't work with mobile computers to verify that on-hand inventory quantities are accurate. As a result, businesses are forced to use a slow, manual pen and paper inventory counting process. Then inventory counts have to be manually re-entered into QuickBooks. This manual process wastes time, money, and leaves too much room for error. That's where CountIt comes in.
Once Wasp CountIt is installed on your PC, the program and your existing QuickBooks or Microsoft Excel data can be sent to a mobile computer. The mobile computer allows you to scan, count, and verify your on-hand inventory – providing you with fast and accurate data retrieval. After the new counts are taken, CountIt easily transfers new inventory data back to your PC and allows you to update your existing QuickBooks inventory file with the new counts.
CountIt is compatible with all Wasp mobile computers and gives you the ability to use multiple Windows Mobile or CE devices simultaneously to take counts and then transfers the new data from all devices into one file. If barcode labels are required, simply print from within CountIt to a Wasp barcode printer, such as the WPL305, WPL608, or WPL610 or any laser printer. Easily print single adhesive labels, adhesive label sheets, and multiple copies of a label for an item in a single print job.
Wasp CountIt is compatible with QuickBooks 2002 or later and integrates with QuickBooks Pro/Premier/Enterprise US, QuickBooks UK, and QuickBooks Canadian. Use QuickBooks 2012 Enterprise Advanced Inventory Module to easily count inventory into locations.
  • Data import and export wizard
    Data import wizard walks you through the process of collecting data from a QuickBooks file.
  • Easy interface
    Wasp CountIt provides an intuitive interface that allows you to see any items that were counted, uncounted, discrepancies, double counted, and more!
  • You're in charge
    Accept or reject any individual item count and update only accurate information.
  • Utilize the power of QuickBooks
    Leverage your familiarity with QuickBooks or your existing spreadsheet program while adding the accuracy and speed of barcode scanning devices for physical inventory counts. Work with a QuickBooks file, text file, or .csv file. Count the items in moments and know what you have on-hand. Quick view function shows old counts, new counts, the difference between your new and old inventory counts, and new items.
CountIt - box pack - 1 user
Box pack
Category
Business applications - inventory systems
Licence Qty
1 user
Platform
Windows
Category
Box pack
Platform
Windows
Min Supported Colour Depth
8-bit (256 colours)
Licencing
Licence Type
1 user
Supported OS
Microsoft Windows Server 2003, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008
Hardware Requirements
200 MHz - RAM 128 MB - HD 350 MB
Additional Requirements
CD-ROM
Compatibility: PC
License: Box pack
Brand: WASP
Price Range Ex VAT: 100 - 150
