With its 5 inch high resolution color LCD screen, the STU-530 is the ideal signature pad for use at the POS or customer contact point. It offers a very comfortable signing experience with an improved, thin design and a low-profile, flat surface. Its design reflects the market requirements for a modern, robust, ergonomic and reliable signature pad. In addition to capturing handwritten signatures, it can be utilized for branding, marketing or advertising purposes, making it a valid marketing tool also. 1024 levels of pressure sensitivity allow a natural signature capturing, fulfilling legal standards. For secure and safe transactions an AES 256 bit encryption and RSA 2048 bit key exchange is included in the pad. Each unit is assigned a unique hardware ID in order to determine the exact unit that was used for a particular signature. The Wacom pen can be tethered to the pad so it can't get lost. The STU-530 is made for heavy stationary use especially at counters and check-out systems.
- Wacom STU-530 - Signature Set - signature terminal - USB - black, dark grey
- Signature terminal
- Connectivity Technology
- Wired - USB
- Display
- LCD display - 5" - 800 x 480
- Black, dark grey
- 16.143 cm x 17.437 cm x 1.085 cm
- 289 g
- Movement Detection Technology
- Electromagnetic
- Movement Resolution
- 2540 lpi
- Accuracy
- ± 0.5 mm
- Performance
- 200 points per second
- USB bus powered, pen slot
- OS Required
- Microsoft Windows 7, Microsoft Windows XP 64-bit Edition SP2 or later, Microsoft Windows XP SP2 or later, Microsoft Windows Vista SP2 or later, Windows 8, Windows 8.1
- 3-year warranty
- 16.143 cm
- 17.437 cm
- 1.085 cm
- 289 g
- Black, dark grey
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- 2540 lpi
- Accuracy
- ± 0.5 mm
- Performance
- Pressure Levels
- 1024
- Active Area
- 10.8 cm x 6.48 cm
Display
- LCD display
- Diagonal Size
- 5"
- Pixel Pitch
- 0.135 mm
- Colour Support
- 16.7 million colours
- Native Resolution
- 800 x 480
- Image Brightness
- 168 cd/m²
- Image Contrast Ratio
- 600:1
- Horizontal Viewing Angle
- 140
- Vertical Viewing Angle
- 140
- Response Time
- 20 ms
- Backlight Life
- 20,000 hour(s)
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Electronic pen, stylus tether, USB cable (3 m)
- AES, RSA; USB 2.0
- Power Consumption
- 2.5 Watt
- Software Included
- Wacom sign | pro PDF (free download)
- OS Required
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 30 - 80% (non-condensing)
