Your basket is empty
Wacom STU-530 & Sign Pro PDF
Quicklinx: BHP0WS00 Mfr#: STU-530-SP-SET
Type: Digital Transcription
Wired / Wireless: Wired
Colour: Dark grey
Compatibility: PC
Cherry MX Switch Colour: [N/A]
£199.93 ex VAT
£239.91 inc VAT
With its 5 inch high resolution color LCD screen, the STU-530 is the ideal signature pad for use at the POS or customer contact point. It offers a very comfortable signing experience with an improved, thin design and a low-profile, flat surface. Its design reflects the market requirements for a modern, robust, ergonomic and reliable signature pad. In addition to capturing handwritten signatures, it can be utilized for branding, marketing or advertising purposes, making it a valid marketing tool also. 1024 levels of pressure sensitivity allow a natural signature capturing, fulfilling legal standards. For secure and safe transactions an AES 256 bit encryption and RSA 2048 bit key exchange is included in the pad. Each unit is assigned a unique hardware ID in order to determine the exact unit that was used for a particular signature. The Wacom pen can be tethered to the pad so it can't get lost. The STU-530 is made for heavy stationary use especially at counters and check-out systems.
Wacom STU-530 - Signature Set - signature terminal - USB - black, dark grey
Signature terminal
Wired - USB
Display
LCD display - 5" - 800 x 480
Black, dark grey
16.143 cm x 17.437 cm x 1.085 cm
289 g
Movement Detection Technology
Electromagnetic
Movement Resolution
2540 lpi
Accuracy
± 0.5 mm
Performance
200 points per second
USB bus powered, pen slot
Microsoft Windows 7, Microsoft Windows XP 64-bit Edition SP2 or later, Microsoft Windows XP SP2 or later, Microsoft Windows Vista SP2 or later, Windows 8, Windows 8.1
3 years warranty
Signature terminal
16.143 cm
17.437 cm
1.085 cm
289 g
Black, dark grey
Input Device
Wired
USB
Electromagnetic
Movement Resolution
2540 lpi
Accuracy
± 0.5 mm
Performance
Pressure Levels
1024
Active Area
10.8 cm x 6.48 cm
Display
LCD display
Diagonal Size
5"
Pixel Pitch
0.135 mm
Colour Support
16.7 million colours
Native Resolution
800 x 480
Image Brightness
168 cd/m²
Image Contrast Ratio
600:1
Horizontal Viewing Angle
140
Vertical Viewing Angle
140
Response Time
20 ms
Backlight Life
20,000 hour(s)
1 x USB - 4 pin USB Type A
Electronic pen, stylus tether, USB cable (3 m)
AES, RSA; USB 2.0
Power Consumption
2.5 Watt
Software Included
Wacom sign | pro PDF (free download)
Limited warranty - 3 years
5 °C
30 - 80% (non-condensing)
Colour: Dark grey
Compatibility: PC
Brand: Wacom
Price Range Ex VAT: 150 - 300
