Designed for creativity
This pen tablet combines Wacom's finest pen capabilities with intuitive multi-touch support. Gain precision and control, speed your workflow, and take advantage of all the pressure-sensitive capabilities in your favorite creative software, thanks to the innovations built into the Intuos Pro.
Let pressure sensitivity power your creative toolbox
The Intuos Pro creative pen tablet delivers 2048 levels of pen pressure sensitivity and tilt recognition, so you can create with the accuracy and precision of traditional brushes and pens. Control line width and opacity based on how lightly you touch the pen to the tablet surface.
Control & comfort you can feel
The combination of pressure-sensitive pen input with multi-touch gesture support delivers a more fluid, more enjoyable experience as you create. Pan, zoom, and navigate naturally with gestures on the multi-touch surface of the Intuos Pro. Create and access your own multi-touch shortcuts. Enjoy the comfort of the Wacom Grip Pen.
Efficiency at your fingertips
The customizable ExpressKeys™ and Touch Ring on Intuos Pro give you quick access to your favorite software shortcuts. The pen tablet recognizes application-specific shortcuts that you define. The on-screen Radial menu and Express View heads-up display help you stay focused on your work.
Your endless creative toolbox
The multiple levels of pen pressure sensitivity and tilt recognition let you create with the accuracy and precision of traditional brushes and pens while multi-touch gestures let you position and navigate your work intuitively. -
Control you can feel
Pan, zoom, and navigate naturally with gestures on the multi-touch surface that also lets you create and access your own multi-touch shortcuts. -
Efficiency is at your fingertips
Customizable ExpressKeys and Touch Ring give you quick access to your favorite shortcuts while on-screen Radial menu and Express View heads-up display help you stay focused on your work. -
A versatile size, without compromise
This popular size tablet provides an ample workspace, yet still fits conveniently inside most laptop bags. -
Enjoy wireless flexibility
Cut down on cord clutter and enjoy the freedom of working wirelessly.
- Wacom Intuos Pro Medium Special Edition - digitiser - USB - black, silver
- Digitiser
- Connectivity Technology
- Wireless, wired - USB
- Black, silver
- Orientation
- Right and left-handed
- 38 cm x 25.1 cm x 1.2 cm
- 990 g
- Localisation
- English, Spanish
- Movement Detection Technology
- Electromagnetic
- Buttons Qty
- 8
- Movement Resolution
- 5080 lpi
- Programmable buttons, finger-sensitive Touch Ring, soft rubber grip, multi-touch digitiser, ExpressKeys, -/+ 60 levels tilt recognition
- Cables Included
- 1 x USB cable - 2 m
- OS Required
- Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Apple MacOS X 10.6.8 or later, Windows 8
- Digitiser
- Orientation
- 38 cm
- 25.1 cm
- 1.2 cm
- 990 g
- Black, silver
- Localisation
- English, Spanish
Input Device
- Wireless, wired
- Interface
- USB
- Electromagnetic
- Buttons Qty
- 8
- 5080 lpi
- Pressure Levels
- 2048
- Active Area
- 22.4 cm x 14 cm
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Pen stand, nib removal tool, nibs (10 pcs.), colour identification rings, stylus pen
- Cables Included
- Software Included
- Drivers & Utilities
- OS Required
