Wacom Intuos Pro Large
DESIGNED FOR CREATIVITY WITH INTUITIVE MULTI-TOUCH GESTURES
Quicklinx: 91SLWS00 Mfr#: PTH-851-ENES
The Wacom Intuos Pro pen tablet combines Wacom's fine pen capabilities and intuitive multi-touch gestures. It gives you the power to produce professional results with the precision and control you demand from your professional software. Designed for creative work, it delivers a natural and intuitive experience that extends your creative capabilities.
Get the most from your creative software with your favorite pre-selected shortcuts. The Intuos Pro even detects the software you're using and offers optimal selections. Quickly access all your shortcuts through the customizable ExpressKeys and touch ring. Stay focused with the express view display and radial menu. Discover intuitive navigation at the touch of your fingers: pan, zoom, rotate and navigate naturally with gestures, or create your own multi-touch shortcuts.
  • Designed for creativity - just the right tools
  • Your endless creative toolbox
    2048 levels of pen pressure sensitivity and tilt recognition let you create with the accuracy and precision of traditional brushes, pens and markers, while multi-touch gestures allow you to position and navigate your work intuitively.
  • Stay focused and enjoy the creative experience
  • Enjoy wireless flexibility and ergonomics
    Cut down on cord clutter and enjoy the freedom of creating wirelessly. Intuos Pro is designed ergonomically for both right and left hand use, so you'll be comfortable all day.
  • Creative breathing room
    The generous workspace is designed to accommodate artistic styles that require a full-range of motion and creative professionals who work in large formats.
Wacom Intuos Pro Large - digitiser - USB - black
Digitiser
Wireless, wired - USB
Orientation
Right and left-handed
48.7 cm x 31.8 cm x 1.2 cm
1.8 kg
English, Spanish
Movement Detection Technology
Electromagnetic
Buttons Qty
8
Movement Resolution
5080 lpi
Programmable buttons, finger-sensitive Touch Ring, soft rubber grip, multi-touch digitiser, ExpressKeys, -/+ 60 levels tilt recognition
1 x USB cable - 2 m
Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Apple MacOS X 10.6.8 or later, Windows 8
Digitiser
Orientation
48.7 cm
31.8 cm
1.2 cm
1.8 kg
English, Spanish
Input Device
Wireless, wired
USB
Electromagnetic
Buttons Qty
8
Movement Resolution
5080 lpi
Pressure Levels
2048
Active Area
32.5 cm x 20.3 cm
1 x USB - 4 pin USB Type A
Pen stand, nib removal tool, nibs (10 pcs.), colour identification rings, stylus pen
1 x USB cable - 2 m
Software Included
Drivers & Utilities
