Achieving your creative dream.
You're only an Intuos away.
Unleash your creativity with the new Intuos. It includes Wacom's leading pen & touch tablet technology, free downloadable creative software and online training. So whether your dream is starting your portfolio, racking up some `likes', or pushing the limits of creativity, Intuos has everything you need to make it happen.
You're closer than you think
Whatever your creative style - or level of skill - Intuos can help you reach the next level. With four different versions, there's one to match you and your creative work exactly.
And because you already know how to draw with a pen and paper, working with the Intuos pen is simple and natural. As you explore the possibilities, your work will develop in new directions from your very first creation...
Create something amazing
Whatever your artistic ambitions, an Intuos can take you there. Beautifully designed and super-simple to use, each pen tablet comes with a free creative pack that includes downloadable software, services and online tutorials too
Creativity with no limits
Take your skills to the next level. With an Intuos pen in your hand, you can easily switch between pastels, pencils and photo editing tools. Controlling your tablet couldn't be easier either. With touch technology, you can use the same gestures you would on your smartphone to pan, zoom, and navigate your canvas.
Creative software to get you going
Whatever you're into--drawing, painting, photography or comics--each Intuos pen tablet comes with industry-leading creative software* made for what you want to do. Just plug in your tablet, register and download to get started. *Registration required to redeem software and other offers.
Made for a quick start
Getting started couldn't be simpler. Just plug a single USB into your Mac or PC. Install the software driver and you are ready to start. With the help of online tutorials, you'll be creating in no time.
Whatever your creative style - or level of skill - Intuos can help you reach the next level. With four different versions, there's one to match you and your creative work exactly. And because you already know how to draw with a pen and paper, working with the Intuos pen is simple and natural. As you explore the possibilities, your work will develop in new directions from your very first creation. -
Whatever your artistic ambitions, an Intuos can take you there. Beautifully designed and super-simple to use, each pen tablet comes with a free creative pack that includes downloadable software, services and online tutorials too. -
Take your skills to the next level. With an Intuos pen in your hand, you can easily switch between pastels, pencils and photo editing tools. Controlling your tablet couldn't be easier either. With touch technology, you can use the same gestures you would on your smartphone to pan, zoom, and navigate your canvas. -
Whatever you're into - drawing, painting, photography or comics - each Intuos pen tablet comes with creative software made for what you want to do. Just plug in your tablet, register and download to get started. -
Getting started couldn't be simpler. Just plug a single USB into your Mac or PC. Install the software driver and you are ready to start. With the help of online tutorials, you'll be creating in no time. -
Sleek and chic
The fresh design is super slim, ultra-light, comfortable to use and portable.
- Wacom Intuos Photo Small - digitiser - USB - black
- Digitiser
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 21 cm x 16.9 cm x 1.1 cm
- 290 g
- Multi-Touch
- Movement Detection Technology
- Electromagnetic
- Buttons Qty
- 4
- Movement Resolution
- 2540 lpi
- Performance
- 133 points per second
- Eraser, multi-gesture touch pad, multi-touch digitiser, ExpressKeys
- OS Required
- Apple OS X 10.8.5 Mountain Lion or later, Microsoft Windows 7 / 8 / 10
- Digitiser
- Orientation
- 21 cm
- 16.9 cm
- 1.1 cm
- 290 g
- Black
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- Multi-Touch
- Buttons Qty
- 4
- 2540 lpi
- Performance
- Pressure Levels
- 1024
- Active Area
- 15.2 cm x 9.5 cm
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Stylus holder, replacement pen tips, colour identification rings, stylus pen, USB cable
- Software Included
- Drivers & Utilities
- OS Required
